Question So 1080ti or 2080 ? next card for next two years or just wait for AMD?
Discussion in 'Virtual Racing League' started by PIM1, Sep 25, 2018.
  1. Zed
    USA
    5,845Coins
    Edit- Just realized this is totally slanted to VR. For regular monitors, I don’t know... ;-)
    Edit 2 - JDI isn’t shipping 4k displays this month. They are 2160 x 2432 RGB LCD - whatever that is commonly called. Here’s the release: https://www.j-display.com/english/news/2018/20180510.html
    There’s still a couple of things to consider between 9, 10, and 20 series cards. Between 9 and 10 (and above), 9 series can’t do single-pass rendering which can cut CPU loads nearly in half since the CPU only needs to describe the scene once. In CPU bottlenecked apps, that can make a big difference.
    Between 10 and 20 it’s a little more muddy. True, the regular performance difference isn’t huge but it is there. If you need the extra performance, the 20 series has it. At least some of it. But there may be a bigger difference soon.
    The upper 20 series models have VirtualLink ports. Japan Display announced they would be shipping (not) 4k displays in production quantities late this month. This may or may not have anything to do with Valve leaking photos from last summer of a headset in test with JDI stickers on them. You can’t push 4k images at 90 or 120 Hz over DP or HDMI unless you just send low resolution and upconvert. To send it native takes VirtualLink. But at that resolution you also need eye tracking and foveated rendering to make it practical even on 20 series cards. And a year ago, Jensen Huang mentioned RTX cores could do foveated rendering which opens the door to simultaneous high and low res rendering for foveated rendering.
    Lots more questions involved but each level has significant advantages depending on what headset comes out soon (if it comes out soon), what software support it needs and when Nvidia would actually support it, when apps would support it, and what apps you run.
    It’s turned into a tougher question.
  2. Curtis
    Curtis New Member
    112Coins
    SCN5
    Regardless of ray tracking, the 2080 is not much better than the 1080, and I'd love to see how AMD develops.
  3. Ming2he
    Ming2he New Member
    212Coins
    Now the price of the display card is constantly rising, and my 970 has been used until now and I dare not replace it.
  4. Diving Delica
    Diving Delica New Member
    Commercial Diver
    Perth, Australia
    179Coins
    Does anyone have more updates on this ??
  5. Zeroselect
    Zeroselect Member Gold Contributor
    Maryland, USA
    111Coins
    4DOF
    Currently i'm running 2x 1080ti 11g and its just enough to run my Qculus Link. I think my next upgrade won't be till Hopper architecture is out bypass the Turing and Ampere architecture.
    152,965Coins
    +11,115 / 56 / -2
    Just so you know the vast majority of VR, with only a few rare exceptions, cannot use dual graphics cards.
  7. Zeroselect
    Maryland, USA
    111Coins
    4DOF
    Yeah, I know. In fact most games isn't even optimized enough to be worth running SLI. Rest In Peace SLI.
  8. Keith
    Keith Active Member
    Electrician
    Canada, Saskatchewan
    154Coins
    Im still rocking a gtx 1070 and an I5 2500k @4.9ghz. Im holding out for the next generation of video cards
  9. yangsqr
    yangsqr Member
    - 21Coins
    For reference: RTX2070 super, 4k display, effects are all very high in ACC, only 50 frames
  10. 김민혁
    김민혁 Member
    - 5Coins
    We recommend the newly released 30 series. Better performance than the previous generation, but at the same or less expensive price
