Tutorial SPS - Sabertooth Packet Serial PID motor driver sketch w/SoftStart
Discussion in 'SimTools compatible interfaces' started by BlazinH, Nov 10, 2016.
  1. TSHracing
    TSHracing New Member
    Canada
    299Coins
    Yes I even ran a simple test sketch that does simple math and montiored that on the serial monitor to see if comunicating with the borad is good.
    I have one question about the UDP port setting in the ini file, where can find that (if it needs to be changes?)
  2. Pit
    30,516Coins
    AFAIK you do not need to change the UDP port. Try another USB port, do not use usb hubs, unplug all other not needed usb devices, set all parameters in the device manager correctly, it should work without changing any parameters of SMC.
  3. thecures
    thecures New Member
    68Coins
    hello .... the syren 50 is not mentioned .... how should i set the dip-switch?...tks
  4. FredBasset
    FredBasset Member Gold Contributor
    461Coins
    Ignore below, worked it out. :)
    Can I ask a simple question, before I get into this too much. I have everything wired up on the bench and I think its working. However my target position is always the centre of the graph, if I manually move the motor it will recenter and stop. I'm probably being dense but I can't see how to change the target, the three buttons to the right of the graph don't do anything.
    As I say, probably being dense, what am I missing.
    Regards
    Fred
  5. Pit
    30,516Coins
    to use this function out mode must be manual
  6. FredBasset
    461Coins
    Thanks, yeah I worked it out.
    I've got my motor nicely dialled in now, however although values are being written from the SMC3Utils program to the arduino for kp, kd and deadzone for example and being retained when its powered down, this isn't the case for PWM Max, this value is never retained, should it be?
    Fred
  7. MarkusB
    4,215Coins
    Exactly this topic already has its own thread:
    https://www.xsimulator.net/community/threads/smc3-saving-settings.14963/
  8. Pit
    30,516Coins
    yes it should, obviously a new bug of Windowsneverendingstory...I had never ever any issues.
  9. FredBasset
    461Coins
    lol, weird its not affecting all values.
    Can I modify the arduino code to use the value I've worked out and not read from the eprom?
  10. BlazinH
    16,701Coins
    With additional feedback received from many people vs only one I now know where the issue resides and I'm looking into a fix for it.
  11. BlazinH
    16,701Coins
    Untested fix but have high confidence :). Let me know!
  12. FredBasset
    461Coins
    Thanks BlazinH, only time for a quick test this morning but it solved my problem with PWM Max not being retained.
    Thanks so much.
    Fred
  13. BlazinH
    16,701Coins
    Great. Can someone else confirm the fix works for them also so I can move the sketch to the first post?
  14. bbb8cd
    bbb8cd New Member
    St. Louis, MO, US
    107Coins
    I was having the same issue as @Reece152 and @FredBasset with the version in the first post; rewrote the Arduino with your 8.2 sketch and it seems to have fixed the problem.
  15. Jorge de Marchena
    Jorge de Marchena Hobbiest Gold Contributor
    Electronic Engineer
    Estados Unidos
    187Coins
    @Pit and @noorbeast
    If i use SABERTOOTH 2x32 i don't need to connect the pot to the motor shaft?
    How many motors could i drive with each SABERTOOTH?
    Using @RufusDufus SMC3 which will be the wiring diagram for 3 motors? How many SABERTOOTH i will require? How many ARDUINOS?
    You both are the BIBLE, your comments will be highly appreciated.
  16. noorbeast
    154,750Coins
    +11,196 / 57 / -2
    Use @BlazinH's modified SMC3 code for Sabertooth, with 2 motors per Sabertooth: https://www.xsimulator.net/communit...ket-serial-pid-motor-driver-for-arduino.9277/
  17. jknajfkae
    jknajfkae New Member
    41Coins
    2DOF, 3DOF, Arduino
    Hello. I follow this method, but the two motors cannot rotate in the same direction. Is the potentiometer welding wrong?:(
  18. noorbeast
    154,750Coins
    +11,196 / 57 / -2
    Sound like you need to either reverse the wires to the motor being tested –OR– reverse the +5V and GND wires to your feedback pot for the motor being tested (do not do both).
  19. BlazinH
    16,701Coins
    If both motors follow pots correctly then use simtools to reverse motor. Otherwise reverse leads to the motor going opposite.
  20. iLLuac4
    iLLuac4 Active Member
    893Coins
    Hi. I am ooking into the code and from what i can see this is the one I can use for all the modes. Am i right?
    I can define eather mode 1, 2 or. 3 for motor drivers?
    Because this is the one that has fixed the write values. So basically this is the latest one with all modes defined.
