Question Star Wars: Squadrons is Coming with VR Support! Motion Possible??
Discussion in 'Other Flight Simulation Games' started by Michael Jeffries, Jun 16, 2020.
  1. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    well, i made some adjusts for joy plugin, and works perfect on my logitech x56 hotas ! Dont forget, space its a diferent local. in SWS, yaw represents left and right positions, with opposit directions on sim. and roll just do nothing ! Video is on portuguese but its easy to se movements.
  2. Wanegain
    Wanegain Active Member
    Bruxelles
    2,008Coins
    It's crashing all the time for me...
  3. paulopsx2
    brasil
    647Coins
    In vr? Normal mode? Whats about your config?
  4. Wanegain
    Bruxelles
    2,008Coins
    I did not try in normal mode, only VR... I bought the game on steam.
    The game does not jerk and remains fluid but after few minutes the computer freezes and I have to reboot :-(
    Ryzen 7 2700X
    Saphhire Nitro+ RX Vega 64
    MSI X470 Gaming plus
    G.Skill DDR4 16Go
    Valve Index
  5. paulopsx2
    brasil
    647Coins
    This is because steam VR Just put energy mode at the maximum power. In this state, ryzen 2700x Works in Full GHz, and reach hot high temperatures. When steam VR initiate, open your Pc energy configuration and change for "balanced" manually. This should be resolve your problem. If dont, change voltage in BIOS Motherboard ( or using ryzen master ) between 1.3v Max.
  6. Wanegain
    Bruxelles
    2,008Coins
    thank you for the tip! I will try very soon :)
  7. SilentChill
    20,594Coins
    Ahh cool so be fine for story mode but no motion available for online
  8. locotoki
    locotoki New Member SimAxe Beta Tester Gold Contributor
    Seattle, WA
    186Coins
    3DOF, SCN5
    Is Game Vibe compatible or planned? Anyone knows?
    152,523Coins
    +11,085 / 56 / -2
    Not likely, given what we know so far, an easier alternate option would be using audio via a low pass filter to drive transducers.
  10. Mechromancer
    Mechromancer Active Member Gold Contributor
    434Coins
    Played the last couple of days in VR with the Pimax 5K XR and joystick plugin.
    I maxed out the settings in the Tuning Center and set Smoothing to 100% it's all pretty smooth. You just have to remember to read the axis in Tuning Center to get motion.
    Great fun for a 43 year fan of the franchise!!
  11. paulopsx2
    brasil
    647Coins
    I'm using André simshaker for aviators, and It works on 2 quad amplifiers 8 aura shakers
  12. paulopsx2
    brasil
    647Coins
    It Works?
  13. rafinnovation
    rafinnovation New Member
    Suisse
    44Coins
    Joyrider
    This game is amazing with joystick pluging and atomic A3 seat !!! works great! I spent 2 hours to configure but, it's good and it works really well.
  14. paulopsx2
    brasil
    647Coins
    whats about "atomic A3 seat"?
  15. noorbeast
    152,523Coins
    +11,085 / 56 / -2
  16. bendrexl
    bendrexl New Member
    USA
    101Coins
    Any tips or guides on setting up a low-pass filter for transducer signal? Is this doable in software while still getting game audio through VR headset?
  17. noorbeast
    152,523Coins
    +11,085 / 56 / -2
    A low pass filter in software is possible: https://www.reddit.com/r/oculus/comments/2kd05t/my_free_bass_shaker_equalizerlow_pass_filter_setup/
    And yes there are various ways to mirror audio, you can even do it with Windows itself: https://www.xsimulator.net/communit...or-and-cv1-at-the-same-time.9812/#post-127089
  18. bendrexl
    bendrexl New Member
    USA
    101Coins
    Thanks! I'll give those a try :cheers
  19. Bastiuscha
    Bastiuscha Active Member
    750Coins
    Simshaker really supports Squadrons? Wow, i really didn't expect that... i'll try that out.Thanks for the suggestion.
  20. noorbeast
    152,523Coins
    +11,085 / 56 / -2
    Check first, it seems to say Microsoft Flight Simulator 2020, DCS World, Microsoft Flight Simulator X, Prepar3D and X-Plane 11 are supported, can't see where Squadrons is supported.
