Wagnard
Star Wars Squadrons XML (STEAM version ONLY) 4.2
Star Wars Squadrons XML plugin for 4.2
  1. Rodrigomarcos1978
    Rodrigomarcos1978 New Member
    Brasil
    103Coins
    The patch does not ask for the path.. When Simtools is installed, it shows a message that the patch was successfully installed.. When starting the game, the game engine shows that it is in game, but the platform does not move.
  2. Rodrigomarcos1978
    Brasil
    103Coins
    confirmed that the plugin does not work with the version purchased from Origin. I bought it through steam and now it works perfectly.
  3. eightbit
    eightbit Active Member Gold Contributor
    Fish Farmer
    Trentham Cliffs
    183Coins
    3DOF, DC motor, AC motor, Arduino, 4DOF
    May the 4ce be with Wagnard everyday! ^
  4. Alexandretrom
    Alexandretrom New Member
    - 264Coins
    Paulopsx2, thank you, it works grest, but just with the STEAM version, with the ORIGIN version dont works.
  5. margolle
    margolle Member
    104Coins
    hello, it still does not work and everyone is mad. thank you community.
  6. dirigible
    dirigible Member
    Ontario, Canada
    137Coins
    2DOF, SCN5
    Hi, all.
    I'm having trouble following this thread because it appears we have discussions about two different Squadrons plugins going simultaneously. I followed the instructions quoted above, then entered my settings in Game Engine, then installed the patch through Game Manager. I launched through Steam. The game still runs fine, but no motion. Can someone please tell me if I'm missing steps?
    Thanks!
  7. paulopsx2
    paulopsx2 Active Member
    brasil
    648Coins
    First: do you have STEAM version?
  8. dirigible
    dirigible Member
    Ontario, Canada
    137Coins
    2DOF, SCN5
    Yes, I am using Steam.
  9. dirigible
    dirigible Member
    Ontario, Canada
    137Coins
    2DOF, SCN5
    Update: I got it working by swapping in the plugin from @paulopsx2 (post #62 in this thread). I've never played a game where motion is tied directly to the joystick data. Interesting. Not as immersive, but the immediate response is certainly fun.
    Thanks to everyone who made this plugin happen!
  10. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,343Coins
    Please note that it's not an updated plugin, he just posted MY plugin with MY xml from post #24
    I'll update the main plugin, something I should have done long ago...
  11. Wagnard
    Wagnardsoft
    5,343Coins
  12. dirigible
    dirigible Member
    Ontario, Canada
    137Coins
    2DOF, SCN5
    Thanks for the clarification--I wasn't aware of this.
  13. Mechromancer
    Mechromancer Active Member Gold Contributor
    434Coins
    Any chance of a STv3 plug?
    Hate to ask, it must be alot of work, but I'm really liking STv3 and I'd like to use it exclusively without having to exit and launch 2.6 to play Squadrons.
    Thanx
  14. Wagnard
    Wagnardsoft
    5,343Coins
    I'll try to do it on my free time.
  15. Mechromancer
    434Coins
    AWESOME!
    Thanx Wagnard!
  16. lysa elec
    lysa elec LYSA ELEC
    16Coins
    the pluging 4.2 not work for me with stat wars steam version
    i just install the pluging but the simul not move
  17. Mechromancer
    434Coins
    I have Squadrons Steam Version and it works for me. Did you have movement before? Are you using SimTools v3? It won't work with v3 right now.
    Is this the first time you use the plugin? There's a special setup if this is your first time:
    1. Renam starwarssquadrons_launcher.exe to starwarssquadrons_oldlauncher.exe
    2. Under a command line with administrator privileges, I went to the \SteamLibrary\steamapps\common\STAR WARS Squadrons\ folder and typed in the following command:
    mklink starwarssquadrons_launcher.exe starwarssquadrons.exe
    This will create a symbolic link from the launcher filename to the real main.exe
    3. In the Windows explorer, open the properties dialog of the symbolic link icon and tick the box "read-only" so that it won't be automatically replaced (not sure it's bullet proof though).
    4. To launch the game, do not start the main exe directly but simply click on the start button in Steam. You can even directly launch Squadrons in VR mode.
    • Dislike Dislike x 1
  18. Kenshiro27
    Kenshiro27 Active Member
    253Coins
    2DOF, 3DOF, Arduino
    Good morning
    first of all thank you for this achievement
    unfortunately it doesn't work for me
    I uninstalled easy cheat as indicated in the discussions
    we feel that simtools starts but as a result the game is blocked by it asks me to install easy cheat
    any solution please?
  19. Wagnard
    Wagnardsoft
    5,343Coins
    Just to let everyone know, I pushed a SimTools v3 plugin recently for Squadrons Steam Version
  20. Mechromancer
    434Coins
    Got it a couple of days ago. Haven't tested it yet. I'll post tonight.
    Thanx @Wagnard, appreciate all the hard work!
