traction loss - slow break out, fast return
Discussion in 'SimTools DIY Version' started by Pit, Nov 9, 2014.
  1. Gadget999
    12,132Coins
    SMC3 is a circuit board designed to control the actuators
    153,782Coins
    +11,150 / 57 / -2
    SMC3 is not for testing, it is the code and configuration for the hardware.
  3. Arielnac
    Arielnac Member
    Argentina
    240Coins
    But I used a software called SMC3 where I set the kp and the PWMmax for example to test only. Then don't use it anymore.
    153,782Coins
    +11,150 / 57 / -2
    Correct, once an Arduino is properly setup with SMC3 you don't need to run the configuration utility, but @Pit is giving advice on SMC settings he used, as that affects hardware responses.
