Tronic's DIY dual Mosfet H-bridge (DSMhb)
Discussion in 'Motor actuators and drivers' started by tronicgr, Dec 30, 2007.
  1. kbssa
    kbssa New Member
    Brazil
    Hi all,
    I have been searching an alternative to substitute the IRLZ44N and I found some.
    IRL1104 http://www.irf.com/product-info/datashe ... rl1104.pdf
    IRL3713 http://www.irf.com/product-info/datashe ... rl3713.pdf
    Thanos, do you think that these guys will heat less than the IRLZ44N ?
    I wanna do a test, with one of them, I think I will do with the IRL1104 cuz it's cheaper, but if it fry as IRLZ does I will do a air conditioning with a peltier module. If you don't know what I'm talking about, google it !!
    What do you think guys !
    I'm tired of changing burned mosfets !
  2. xtech007
    xtech007 Member
    29Coins
    Hi All!
    Do anyone have a final tested list for fets?
    I have IRFL44N and IRF4905L and still no luck :eek:
    Has anyone change the IRF4905L?
    or the IRFL44N for anything else and tested?
    Thanks in advanced!
  3. TheXRacer
    TheXRacer Cougarsimulations SimAxe Beta Tester
    349Coins
    2DOF, 3DOF, DC motor, Arduino, SimforceGT
    Hello all,
    I got my H-bridge (Tronic `s DIY dual MOSFET H-bridge) built.
    Now I have always the problem that my mosfets overheat :eek: :thbd:
    Why is that everything is soldered properly! 3x checked! :thbup:
    P-channel MOSFET IRF 4905
    N-channel MOSFET 44 IRFZ
    All are constructed as in the plan, it all works just the mosfets too hot
    Please write me back if you have a solution / assistance :thbup:
    best regards
    Christian
  4. RaceRay
    23,877Coins
    I wrote you a pm
  5. TheXRacer
    349Coins
    Yes I see it :D !
  6. futuresims
    futuresims New Member
    24Coins
    I am following this thread.
    Can you please fill the rest of us on the overheating problem.
    Thank you very guys.
  7. TheXRacer
    349Coins
    Hy futuresim the problem of my H-Bridge are not solved , at the moment i`m on testings. When i found the error i will postet him !
    regards
    Christian
  8. trust928
    trust928 Member
    brazil
    435Coins
    hey I'm curious to know one thing..... I'm planning to use 90v motor.. what could i change in this h-bridge,, to let me use this voltage?o_O i mean if this is possible..
  9. eaorobbie
    20,491Coins
    This is dead in the water mate , originator doesn't use it anymore or support it, most peoples unit never ran past 12v 15amps before mosfets blew up.
  10. rafael_design
    rafael_design Member
    CGI Architectural Visualizations with Blender 3D
    Brasil
    328Coins
    One thing that helped me a lot with this burning mosfets issue is that you have to be able to test them. Remember that one bad apple spoil the whole bunch ;D
    simple and efficient way for testing mosfets spanish version:
    Other VERY important thing to have in mind is that ALWAYS test your h-bridge carefully until it is working fine for sure.
    You have to be sure that the potenciometer is in middle position (meaning the motor would stay stopped and almost no current will flow) and then slowly turn it a little back and forth checking the mosfets temperature.
    With NO LOAD to the wiper motor, you have to be able to touch mosfets without burning your fingers even without a fan blowing air into it.
    If anything else happens you should check again all mosfets for that motor (Thanos h-bridge has two groups of four mosfets for each motor) and also check for shorts and open circuits.
  11. bsft
    As Rob says, this is a history board now, there are better options out there, but thanks for the info though.
  12. Alexandre Kostik
    Alexandre Kostik Member
    realtor
    Brasil
    422Coins
    Hello tronicgr ! I built two bridges with the circuit which shall be attached , but only after I realized I had no way to enter the PWM signal. Please answer me some questions if possible :
    - Can I use the logic circuit that you did on your bridge and turn on my bridge ?
    - Ard What code do you use to control the simtools ?
    - What is the supply voltage of the logic circiuto ?
    - I read in a post Prylad the need for galvanic isolation ? Is this necessary?
    Grateful.
    If you can not use them I will build like yours ..
    PS : sorry for the english ... use translator !
  13. Alexandre Kostik
    realtor
    Brasil
    422Coins
  14. bsft
    go to his blogspot and ask
