Tronic's DIY dual Mosfet H-bridge (DSMhb)
Discussion in 'Motor actuators and drivers' started by tronicgr, Dec 30, 2007.
  1. tronicgr
    tronicgr
    Can you post photos of your motors? Are they car wiper motors?
    You can try using smaller DC motors (from toys) if you like but then you have to use lower motor supply voltage too (most toy motors are 6volts). This will verify that there isn't something wrong with your h-bridge.
    Thanos
  2. dallaby
    dallaby New Member
    Thanks for the reply... I haven't taken pictures of my motors yet but I have tried your suggestion with different small motors, and lower voltage supplies.. Still appears to have the same results..
    I have tried to change my 74HC chip as that was an easy test... no joy... It is weird that without a motor connected the status led's display properly and when I change direction they respond quickly and bright... But when I connect a motor it is kinda like the fet's aren't turning on properly for some reason...
  3. egoexpress
    It's a soldering mistake most likely. Recheck all solder spots, and have a look on the leads, perhaps there is a shortcut somewhere.
    Or the RX TX wires are wired crossed.
    Dont forget to isolate the GND from motor housing.
    regards
  4. dallaby
    dallaby New Member
    I will triple check this again however I did go over everything with a multimeter and magnifing glass... thanks for posting back... So there would be no issues with the amount of power output by my arduino PWM pins? I believe it is only capable of 250ma..
  5. tronicgr
    tronicgr
    Why I have suspicion that you use the same power source for motors and for arduino?????? The motors must have their own power source with their grounds isolated from the Adruino ground !!!!! :eek:
    The Arduino does not drive the mosfets!!! The signals it needs to sent are a few uA only. The driving of the mosfet gates are done from the four transistors placed next to the mosfets!
    A photo of your connections would help! A picture is a thousand words!!!
    Thanos
  6. dallaby
    dallaby New Member
    I will try and get you some pics... I am definitely using an external power supply for the motors and the grounds are not connected in any way...
  7. Senetor
    Senetor Member
    Australia
    594Coins
    Hi Thanos,
    any advancements on using the ACS756 Hall Effect Current Sensor as I have just received 6 samples of the ACS756 and the A3941 devices from Allegro, took about 6 weeks to arrive but at least they were free.
    Regards Senetor.
  8. stefkefsx
    stefkefsx New Member
    Belgium
    893Coins
    does anyone know where to buy the parts for the h-bridge? :sos:
    stephane
  9. stefkefsx
    Belgium
    893Coins
    I want to build a h-bridge, could someone please upload a bom import list for mouser.com? :happy:
  10. adochoa
    adochoa New Member
    1Coins
    I have built both AMC controller and H bridge. The controller seems to be working perfectly as the LCD does everything it should. It responds to Pots and slider bar of profiler. when I attach the H bridge howver, nothing happens. No lights or motor movement of any kind. My wiper motors are not grounded to frame, and the H bridge/AMC are separated also. I am also confident my wiring is correct from controller to H bridge.
    Are there trouble shooting tips anyone can advise me on? Is there an easy way to determine if my Mosfets are OK?
    Thanks for any help,
    Dave
  11. tronicgr
    tronicgr
    Hi Dave,
    Perhaps you placed in wrong direction the 74HC08 chip, or made wrong connection on the cable that connects the AMC and the DSMhb boards... Also be sure to have installed the mosfets in such way that they facing back to back!!
    Some photos from your boards with cabling installed would help to determine the problem.
    Here is a simple mosfet tester that you can build on protoboard:
    http://www.x-simulator.de/forum/post12552.html#p12552
    Regards, Thanos
  12. knob2001
    knob2001 Member
    Madrid, Spain
    24Coins
    Hi!...
    After the lost of my little and beloved pololu ( :cheers: where ever you are, pal), i've nearly finnished the DSMhb... but in all the stores at my place is impossible to find the Mosfets... i just found one that will import them for 9€ each, but i don't want to pay the honolulu holidays to the store man. At least not in crisis times
    So... i've seen some german places (on the AMC topic there's a list in german) as cheap as 0'90€ each... how could it be possible? Anyway, i really need some one here to help a little. The stuff i need:
    8x - IRF4905 (TO-220) (Better 8 instead of 4 becouse i will blow them for sure... or not, who knows)
    8x - IRFZ44 (TO-220) (Same as above :mug1: )
    Ah, this is not on this part list, but the Hall sensors are like asking for cold fusion... impossible, impossible. soooo... add:
    2x - sensor Hall ss495
    If someone knows how to ask them from internet to my place (spain) or to your place and i will pay whatever is needed and a little charge if you need to move to post office... please, you will earn an ilimited bonus freeride on my sim (and a couple of beers between).
    Thankyou in advance.
    knob2001 (joyrider + AMC + DSMhb + Freetrack)
  13. tronicgr
    tronicgr
    Hi Oscar,
    You can find those parts in ebay in lots in nice value:
    10x IRF4905:
    http://cgi.ebay.co.uk/10PCS-IRF4905-Tra ... .m63.l1177
    10x IRFZ44:
    http://cgi.ebay.co.uk/10-pcs-IRFZ44N-IR ... 240%3A1318
    And you could even buy the stronger replacements of IRFZ44, the IRF3205:
    http://cgi.ebay.co.uk/IRF3205-BY-IR-LOT ... .m63.l1177
    As for the ss495, I know, they are amazing devices. Too bad that they are hard to find. I had to order 10 of them to get a better price when I ordered them from my local supplier. Here is a tool I often use to locate on-line sources for parts: http://octopart.com/search?q=ss495
    Best Regards, Thanos
  14. devincox
    devincox New Member
    IT Guy/Programmer
    352Coins
    @stefkefsx,
    I was working on this for myself and have not purchased these yet, so the list may need to be re-checked to confirm accuracy. but here is a BOM for mouser.com. Just cut and paste the list below into the BOM import tool. It does not include the wire. Other than the wire everything else is there. Total cost before shipping is $40.03.
    I must say though, that getting the mosfets on ebay, as suggested by TronicGr will save some coin and give extra parts in case you blow one up. Once this BOM is verified it will go in the Wiki, so if you find any mistakes please let me know. thanks.
    595-SN74HC08NE4|1
    511-STP80PF55|4
    844-IRFZ44PBF|4
    512-BC546ABU|4
    271-3.6K-RC|4
    660-MF1/4DCT52R2201F|4
    660-MF1/4DCT52R1501F|4
    660-MF1/4DCT52R6800F|2
    271-160-RC|4
    821-1N5819|8
    512-1N5245BTR|8
    647-UVR1J101MPD1TD|2
    433-SP501012H|1
    538-39544-3002|4
    538-39543-3003|8
    649-DILB14P-223TLF|1
    538-26-60-4100|1
    538-09-50-3101|2
    538-08-50-0105|15
    859-LTL-4234|2
    604-WP7113ID|2
  15. tronicgr
    tronicgr
    Hi Devin,
    The list is ok except of the 12V PC fan, that is too small. I removed it from the list. We need a 80x80mm fan that can be found in any computer shop.
    595-SN74HC08NE4|1
    511-STP80PF55|4
    844-IRFZ44PBF|4
    512-BC546ABU|4
    271-3.6K-RC|4
    271-160-RC|4
    821-1N5819|8
    512-1N5245BTR|8
    538-39544-3002|4
    538-39543-3003|8
    538-26-60-4100|1
    538-09-50-3101|2
    538-08-50-0105|15
    859-LTL-4234|2
    604-WP7113ID|2
    :thbup:
    Regards, Thanos
  16. R-eng
    R-eng Member
    San Diego, CA, USA
    28Coins
    The modified DSMhb (expresspcb version) is spaced for a 92mm fan.
  17. tronicgr
    tronicgr
    Hi R-eng,
    Yes, I know. The above BOM list is for the PCB plans I gave for PDF layout DSMhb1.2b that has 80mm fan mounting holes...!
    Regards, Thanos
  18. devincox
    devincox New Member
    IT Guy/Programmer
    352Coins
    @ TronicGr,
    thanks. Sorry, I didnt pay attention to the spacing on that fan. :)
  19. Michael N.
    Michael N. Member
    Germany, NRW, Düren
    611Coins
    Hi tronic,
    do you think this mosfets are better than the IRFZ44?. Do they not burn quickly as the IRFZ44?. The IRFZ44 are a little bit sensitively :blush: .
    I ordered some to try them.
  20. OscarH
    OscarH Member
    Paris, France
    517Coins
    Hi Tronicgr,
    Any technical reason why on you H-bridge you have 'Motor1 IN1', 'Motor1 IN2' and 'Motor1 PWM Channel' inputs ? Are not IN1 or IN2 always in opposite logic states, except if you use them for break purpose...
    I'm just curious :thbup:
    Cheers.
    OscarH
