Universal 6DoF Recessed Simulator
Discussion in 'Commercial Simulators and Peripherie' started by RobsonSwiss, Jun 21, 2017.
  1. SeatTime
    This recently popped up next to a video I was watching ... I hope he is doing well :thumbs.
  2. RobsonSwiss
    RobsonSwiss Active Member
    Preotria, South Africa
    35Coins
    Hi
    I've been meaning to do a writeup, the arcade wanted it to be "easier" to drive with more movement so we ended up configuring it like this:
    The CHG90 was quite a tricky thing to mount, but it's a really nice display, would highly recommend it.
  3. Gadget999
    12,132Coins
    is that a rack and pinion style actuator instead of a ball screw ?
  4. RobsonSwiss
    35Coins
    Sort of, it's a belt drive.
  5. Zed
    USA
    5,845Coins
    Looks great! Congratulations!
  6. Gadget999
    12,132Coins
    can i find out more about the actuators anywhere - most of the embedded images do not work
  7. RobsonSwiss
    35Coins
    Thank you
  8. RobsonSwiss
    35Coins
    Well I've gone through a few iterations. The are essentially all low inertia, serpentine designs. Right now I'm actually busy testing a cable drum and it works really well, not as direct as the belt/track combination but the smoothest actuator design so far, also completely silent. But they all have one big drawback, they are much more expensive than a ballscrew.
    So for a lower cost option we'll have some ballscrew options. Maybe even as a DIY actuator kit since I have a pretty robust motion controller and most people probably have the ability to build their sims but not make actuators.
    Anyway, I'll make a new thread soon about the new model and explain the drive system.
  9. Zed
    USA
    5,845Coins
    I’ve also been looking at planetary gear winch motors for a cable drive. Only thing is I need a custom drum size to get the right ratio.
  10. RobsonSwiss
    35Coins
    The drum is reasonably simple and your local machine shop should be able to do them for you at a reasonable cost, if you need help on some drawings or to show you how I do it let me know.
  11. BlazinH
    16,689Coins
    The machine shops I've visited don't do anything, "at a reasonable cost" though. I suppose its a matter of your definition of whats reasonable. :D In any case I wouldn't be at all surprised that having a custom drum made would cost more than the cost of the winch itself.
  12. RobsonSwiss
    35Coins
    Well I guess it also depends on how you design the part. For a 50mm roller, 36mm long that I'm using, we'd probably charge around $300 if someone walked in and asked us to make only 6 of them. I think on your side it would be the same, ask them to make 100 and the price would come down to about 1/3rd of that.
  13. Zed
    USA
    5,845Coins
    It’s not about the cost though that is a factor. I’d probably just have a hub machined and build the rest myself somehow. But machine shop costs can be pretty high when you aren’t a regular customer especially if you need keyways and such.
    I was just commenting that it’s not generally an off the shelf part. No big deal.
    The winch/cable method has some real advantages without adding much moving mass.
  14. RobsonSwiss
    35Coins
    Ah okay, yeah give it a go. It works well.
  15. Red_shift
    Red_shift Member Gold Contributor
    Charlotte
    361Coins
    OK, getting excited. Got conformation my DragonFly system has shipped and should get delivered early next week. Can't wait. :) :) :)
  16. isamu
    isamu Member
    267Coins
    Nice to hear :) Please post very *VERY* thorough impressions and a lengthy vid.
  17. Red_shift
    Charlotte
    361Coins
    Will do, although I will need some help on how to post videos. Stay tuned
  18. noorbeast
    153,788Coins
    +11,150 / 57 / -2
  19. Red_shift
    Charlotte
    361Coins
  20. BlazinH
    16,689Coins
    Any update?
