Universal 6DoF Recessed Simulator
Discussion in 'Commercial Simulators and Peripherie' started by RobsonSwiss, Jun 21, 2017.
  1. Rider63
    Rider63 Member
    273Coins
    AC motor, 6DOF
    I understand but I thinks the surface is not wide enough, but it's just my feeling, we will see.
    we wan't more picture ;)
  2. RobsonSwiss
    RobsonSwiss Active Member
    Preotria, South Africa
    35Coins
    You're wrong, the removable bends have about 12 cm/2 of surface area, the datasheet lists 214kg cm/2 lap shear strength, which is the way the bend was designed, so it's not possible to "peel" it loose, this is the same for all epoxy'd parts, they are all in either shear designs or in a combination of shear and peel, the bottom mounts for the actuators are like this, they have around 6 cm/2 of sheer surface per actuator with around 9 cm/2 of peel surface. Unfortunately the datasheet doesn't list typical peel strength so if we go by sheer only it will require over 1200kg of force to remove. The removable bends will be double that, at 2400kg, they run in tandem so that's 4800kg, the permanent bends are double that so 4800kg/9600kg. The supplier told me the aluminium would fail before the joint does and I didn't really believe him, thought it was just sales talk. But even if the joint is just 15% the strength of the datasheet numbers it's still significantly higher than required.
    ref: https://www.amtcomposites.co.za/sites/default/files/media/data-sheets/adekit-a140-h9940-gb.pdf
    Pics will come, I'm busy sorting out the flux capacitor.
  3. RobsonSwiss
    35Coins
    Some pics:
  4. Nitros54
    Nitros54 Member
    villey saint etienne
    119Coins
    Hello, I see you have advanced on your simulator, you do an exceptional job, congratulations to you.
  5. RobsonSwiss
    35Coins
    Some more pics:
    Busy with the base now:
    The platform looks like this:
    The dual platform universal joint.
    • Like Like x 7
  6. RobsonSwiss
    35Coins
    Thank you!
  7. RobsonSwiss
    35Coins
    Assembly is easy, probably about 4 hours to do solo, half that with a helper.
    • Like Like x 7
  8. RobsonSwiss
    35Coins
    Some manual movement testing:
    • Like Like x 8
  9. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
    Don't turn on the ceiling fan when running lol
    Great job so far
  10. riton
    riton Active Member
    1,006Coins
    I'm curious to see it on video
  11. RobsonSwiss
    35Coins
    Lol, well I might have been cheating there and went to the mechanical limit instead of the limit switch, so it's 30mm higher
  12. RobsonSwiss
    35Coins
    A few more wires to go
  13. Red_shift
    Red_shift Member Gold Contributor
    Charlotte
    361Coins
    Wow, great progress. Looking forward to a video :popcorn
  14. RobsonSwiss
    35Coins
    It's coming very soon, some last updates to improve the stiffness of the platform happening and I'll upload it.
    Something else in the meantime, I've got some new drivers with much higher startup current, so I did a side by side, old driver on the bottom, new driver on the top.
  15. RobsonSwiss
    35Coins
    Currently stuck in a motion controller black hole... But the platform is sorted, need to add the top bracing next and hopefully get some working AMC1280 code soon.
  16. Leo Burton
    Leo Burton Active Member
    London, UK
    2,639Coins
    That rig looks awesome! Amazing work! Can't wait to see it in action! There's a lot of travel on that! Turbulence in flying games could be epic!
  17. RobsonSwiss
    35Coins
    Thanks, I'm busy with a small gear reducer on the encoder, which is turning out to be quite tricky, finding local stock of miniature gears is almost impossible, couldn't get the AMC1280 to count multiple turns so for now I'll run a 4:1 reducer.
  18. Thanos
    Electronics Engineer
    United States
    2,871Coins
    Hey Jonathan,
    Can you change the acceleration setting on your servo drives?
    By default my servo had 100ms ramp up down that was causing overshooting....
  19. chrissie
    chrissie New Member
    Munich
    222Coins
    RobsonSwiss, I have just seen your insecta tech website, your product looks very exciting. When will it be available?
  20. RobsonSwiss
    35Coins
    Hi Thanos,
    Was 100ms too high?
    I had it set on 10ms, it was pretty damn fast, could only touch it very briefly with manual input and it would move 250-300mm, but it was probably the SSI encoders, I've pulled all the AMC1280USB related stuff already though, for now I'm working on a new solution.
    Almost done sorting out the motion, so, so close! I'll send out an announcement since there are a lot of upgrades on the chassis, electronics, electrics, actuators etc. that's been finalized while I've been struggling with the motion, so the "2018 version" looks a lot different and has a lot of improvements over the initial concept/design.
