  1. SilentChill
    20,661Coins
    Will try it tonight and let you know
  2. misoswan
    misoswan Active Member
    1,038Coins
    3DOF, Arduino, JRK
    hello
    please video +...Video installation instructions how instal
    many thanks
  3. SilentChill
    20,661Coins
    Ok got it working in revive and initial test is frikkin good !!!!
    Just need to secure my controller better as it keeps moving and throwing the screen off a little.
    Report back in a bit, with a video as well hopefully
    154,729Coins
    +11,213 / 57 / -2
    Did you try the OpenVR setting instead of Revive: https://www.xsimulator.net/community/goto/post?id=132042#post-132042
  5. SilentChill
    20,661Coins
    • Like Like x 5
    • Winner Winner x 4
  6. SilentChill
    20,661Coins
    I can't tell you how good this stage was. It works so well and felt so so good.
    Now I got it working I best go fix that ED plugin lol
    • Like Like x 8
  7. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    Wonderful SilentChill!!! :cheersWhat linear actuators do you use? They do not look scn5.
    Compliments!!!
  8. Zed
    USA
    5,847Coins
    This is very cool that it works so well! Damn, I can't wait to get my motion going!
    @ilbiga - he built those actuators and details are in his build thread in the DIY motion simulators forum.
  9. ilbiga
    Network Engineer
    103Coins
    Thanks ZED, I missed updating with linear actuators.
    Really interesting. I still have not finished the 2DOF and I guess I felt like a 6DOF.
    Sin not to have time! :(
  10. Brandon Naids
    Brandon Naids TalonSim
    Orlando, FL
    - 103Coins
    2DOF, 3DOF, AC motor, Motion platform
    Assetto Corsa works with OpenVR. I've been trying different games out all day and I'm getting great results! Occasionally it will bug out and start moving me vertically whenever my motion platform moves. Has anyone else run into this problem? It may have something to do with where I mount the controller. Right now I have it mounted to the seat right behind mi head, but i think the cameras have a hard time tracking it there. I'm working on a mount to raise it right above the seat. I'll post pics tomorrow if anyone is interested.
    154,729Coins
    +11,213 / 57 / -2
    Please do post further info and pictures and also report the vertical movement to the dev here, so we can sort out if it is a bug or not: https://www.xsimulator.net/community/threads/low-cost-2dof-motion-simulator-kit-dynamic-kit.8570/
  12. Zed
    USA
    5,847Coins
    Hey Brandon - also important is which headset you have. I am guessing a Rift since you mention cameras but some don't understand that Vive doesn't use cameras. Also, assuming Rift, how many cameras are you using and how are they configured? If you are only using one camera and it can't always see the Touch controller, it wouldn't be surprising that you would get drift like that. If you are using multiple cameras, it would be interesting if you are seeing Rift drift even when you are running without any motion.
  13. SilentChill
    20,661Coins
    Just use 1 camera for tracking on a motion platform or else it will get very confused, at least that's what I have found with all my testing.
    I cover my other 2 so they can't see anything.
  14. Fluke
    Fluke Member
    Stafford, United Kingdom
    812Coins
    Is anyone still using a 2 axis GoPro stabilizing gimble? I thought this was supposed to be the best way to solve the problem?
  15. noorbeast
    154,729Coins
    +11,213 / 57 / -2
    A gimble was a way to try and work around issues created by mounting a Rift camera on a rig.
  16. Zed
    USA
    5,847Coins
    Hey Fluke, the way tracking works on both the Rift and Vive makes a gimbal kind of a kludge. It doesn't actually solve the problem because there are two components to motion tracking. The major tracking method is using inertial sensors since those can be read fast and don't accumulate much error over short time periods and distances. The optical part with laser scans or cameras only serves to provide periodic anchors to the inertial data. If the headsets only used optical tracking, mounting a camera or Lighthouse on the platform would work perfectly. But with the software paying more attention to the inertial information, mounting the optical tracking on the platform only partially corrects for motion and may even induce some sort of micro shaking (can't say since I can't test but Silent Chill would know).
    Mounting a camera on a platform and using a gimbal to kind of correct for what the inertial sensors are doing might work to some extent but the nature of camera tracking and it only being periodic updates to what the inertial sensors are telling the software means it will never fully compensate for a moving platform.
    The real solution is to just subtract the motion of the platform from the motion of the headset. Inertia from a movement of the platform will be seen by both headset and platform sensors and get subtracted away. Movements relative to the platform won't subtract away. They both get the same periodic optical fixes and both read inertial movement just fine. As long as both position and acceleration are subtracted, it should work perfectly.
    • Agree Agree x 3
  17. SilentChill
    20,661Coins
    Couldn't of put it better myself. This is a huge huge breakthrough and it does the job perfectly.
    • Agree Agree x 3
  18. Fluke
    Fluke Member
    812Coins
    Thanks, that's a great easy to understand reply and makes sense.:thumbs
  19. misoswan
    1,038Coins
    3DOF, Arduino, JRK
    HELLO
    WILL BE WAITING FOR DCS VIDEO :) WITHOUT STEAM :popcorn :grin
    THANKS
  20. SilentChill
    20,661Coins
    Sorry don't play DCS
