Ville Pesonen
War Thunder Plugin 2.0.0.0
SimTools plugin for War Thunder
  1. value1
    14,306Coins
    That would be cool to have a stable plugin that works with the future versions of the game too! :thumbs
  2. Ville Pesonen
    Ville Pesonen Active Member
    871Coins
    Took me many hours but I managed to make something out of it!
    Roll is Roll rate in degrees (so it's not related to the planes angle relative to the earth)
    Pitch is the position of elevator (so it's not relative to the earth)
    Heave is G forces that the pilot experiences
    Yaw is rudder position
    Sway is Sideslip angle
    Surge is calculated from delta speed, so it gets little wonky when you dive.
    Only "problem" with the plugin is that it opens many (6000-7000) tcp connections to localhost . every update request opens new one and it takes some time to close the old ones. but that is what it is as there is no other way to pull the values from the game, except memory hooks.
    I've attached the plugin for people to test. Let me know how it works.
  3. Ville Pesonen
    871Coins
    Ville Pesonen updated War Thunder Plugin with a new update entry:
    War Thunder plugin using TCP
    Read the rest of this update entry...
  4. brucewang
    brucewang New Member
    China
    195Coins
    Can this support Chinese version?
  5. Ville Pesonen
    871Coins
    I do not know as I have not tested it in one. You'll have to give it a go to see if it works.
  6. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    for some reason the screen is completely upside down for me. Anyone else have this issue?
    154,849Coins
    +11,228 / 57 / -2
    I just did the latest War Thunder update and both it and the motion plugin are working for me.
    When you say the "screen is completely upside down" do you mean in normal monitor mode or with the Rift. I currently don't have a runtime switcher installed so can't test War Thunder Rift support at the moment.
    If it is with a monitor what is your graphics card configuration?
  8. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    980 gtx... Triples, I'm on 0.8 so I can't run my dk2
    154,849Coins
    +11,228 / 57 / -2
    Sounds like the latest War Thunder update may have done something that messes with the way the triples are configured. Have you tried a single screen, just to see what happens?
  10. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    I havent but I will try. Should war thunder work in 0.8? Guess I am going to google that now.
  11. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Nope, still not on 0.8 and getting the switcher running was a pain in the ass and I dont like hassle.
  12. noorbeast
    154,849Coins
    +11,228 / 57 / -2
    The Oculus SDK 1 is available for developers so let's hope War Thunder gets to that soon, as they have worked out most of the other VR issues, except for some HUD elements.
  13. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Based on their track record I would very seriously doubt it.
  14. Jamburglar
    Jamburglar Member Gold Contributor
    Controls Engineer / Software Engineer
    Michigan
    186Coins
    I can't wait until I get my seat designed and built. I am also pre-ordering a rift. Too. This is the game I want to play the most!
  15. darkcrayon
    darkcrayon Member
    New York, NY
    305Coins
    3DOF, SCN5, 6DOF
    Does the new plugin work for tank view? If not, is a similar stream of data provided via TCP? That would definitely be a unique vehicle for motion sims :)
    Hmm downloaded it, doesn't seem to give the same info for tanks? You can pull up the web page map but it doesn't seem to include any of the "statistics" for what's going on.. Unless something was wrong on my end.
  16. Ville Pesonen
    871Coins
    I only made the plugin to work with the planes, so the tank part won't work.
    I'll have to try the tank part of the game and see if I can come up with something for it. It might take couple of weeks as I have some other things going on at the moment.
  17. Ville Pesonen
    871Coins
    @darkcrayon
    I finally got around to have a look at the possibility of adding motion for the tank part of the game, but unfortunately it seems like it's impossible to do without memory hooks. The tank mode does not provide the data though tcp.
    The memory hook would brake every time the game is updated so the fun would not last long.
  18. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Guys,
    I am getting no motion from the game.
    Game manager and engine, both running in admin mode.
    Am I missing something here or is it that they updated the game and changed something related to the telemetry?
    Perhaps to add tanks data now! :roll
    Any help is appreciated! :sos
  19. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Nevermind. Working now.
    For some reason I had an old plugin installed. Got the latest one.
    There is just one strange behavior as the pitch has some strange jerk aleatory movements back and forth... lol
  20. noorbeast
    154,849Coins
    +11,228 / 57 / -2
    Try the smoothing filter on pitch.
