Ville Pesonen
War Thunder Plugin 2.0.0.0
SimTools plugin for War Thunder
  1. rickrsr
    rickrsr New Member Gold Contributor
    406Coins
    2DOF, Joyrider
    PluginUpdater does not install War Thunder Plugin 2.0.0.0.
    This is the first time that I am trying to install the WarThunder plugin,
    and although PluginUpdater says things went fine,
    when I run GameManager, WarThunder does not show up in the plugin list.
    I think that I have things set up correctly, because I have had no problems
    installing other plugins, including the very recent
    condor The Competition Soaring Simulator Plugin 2.0.1.1.
    I have taken a look at the Simtools Appdata forWarThunder,
    and I see entries for WarThunder MaxMinProfiles and GameBanneners,
    but no data on WarThunder for GamePathSaves, Profiles, or GamePlugins.
    Thanks for any assistance getting the WarThunder plugin installed.
    154,400Coins
    +11,181 / 57 / -2
    Just to be clear, are you saying you closed SimTools, opened the PluginUpdater, installed the WT plugin, closed the PluginUpdater, restarted SimTools and WT does not show in the Game List under Axis Assignments?
  3. rickrsr
    406Coins
    2DOF, Joyrider
    I did just as you said, except that after I closed PluginUpdater, I just started GameManager because I wanted to patch the game, but I could not patch WarThunder because it was not in the GameManager Game Selection List.
    154,400Coins
    +11,181 / 57 / -2
    Is WT in the Game List under Axis Assignments and if so have you created an Axis Allocation for it?
  5. rickrsr
    406Coins
    2DOF, Joyrider
    WarThunder is not in the Game List under Axis Assignments.
    154,400Coins
    +11,181 / 57 / -2
    Then it is not properly installed.
    Try downloading the plugin again, to ensure your copy is not corrupted.
  7. rickrsr
    406Coins
    2DOF, Joyrider
    I downloaded the plugin again, and the install still did not work (in the same way as the first time).
    I've had no problems with five other plugin installs, with the most recent success being a Condor plugin install
    on the same day that I've been unsuccessfully trying to install the WarThunder plugin - kind of a mystery - Is there any way for me to try installing, say by copying the plugin ZipFile files to appropriate places?
    154,400Coins
    +11,181 / 57 / -2
    First check if there is a balked install and manually remove it from: c:\user\Your_User_Name\AppData\Local\SimTools\GameManager\GamePathSaves
    Which licensed version of SimTools are you using, DIY, Pro or Entertainment?
  9. rickrsr
    406Coins
    2DOF, Joyrider
    I believe that I have a DIY License - I checked that my license key is valid, and when I start up GameManager, it briefly says that a valid license was found and it is not for commercial use. GamePathSaves does not have a WarThunder.cfg file, but there are "WarThunder" files in folders MaxMinProfiles and GameBanners.
    154,400Coins
    +11,181 / 57 / -2
    The splash screen and top right of of Game Engine will tell you what license you have.
  11. rickrsr
    406Coins
    2DOF, Joyrider
    I have a DIY license
  12. noorbeast
    154,400Coins
    +11,181 / 57 / -2
    Have you used administrative privileges at any time, like with the PluginUpdater?
    Perhaps @Ville Pesonen or @yobuddy have further ideas as to why the plugin is not installing properly.
  13. rickrsr
    406Coins
    2DOF, Joyrider
    All my WarThunder plugin install attempts used PluginUpdater not using administrative privileges.
    A few days ago, when I first tried installing the Condor plugin (my first plugin install for pretty long while),
    PluginUpdater did have administrator privileges and the Condor plugin install did not install. But after I took off the administrator privileges, the Condor Plugin install went fine. GameManager and GameEngine do have administrator privileges.
  14. noorbeast
    154,400Coins
    +11,181 / 57 / -2
    You should not really need admin privileges for SimTools.
    I can't really think of another reason why WT does not install, other than it potentially being corrupted.
  15. rickrsr
    406Coins
    2DOF, Joyrider
    Thanks for trying to help.
  16. yobuddy
    51,659Coins
    Maybe for some reason your Antivirus is picking up the plugin as something bad and quarantining it?
  17. rickrsr
    406Coins
    2DOF, Joyrider
    No programs are quarantined, and I even tried turning off my anti virus, but the WarThunder plugin still did not get installed, even though the PluginUpdater said things went fine (the banner and MaxMin files for WarThunder were, however, placed in Simtools AppData). It would be great if there was some way to just manually copy plugin install files to the correct places.
  18. yobuddy
    51,659Coins
    The problem is your trying to load a SimTools v1 plugin into SimTools v2.
    Take a look at the plugins dll name.
    Its "War_Thunder_Plugin.dll" <- this in SimTools v1 naming convention.
    SimTools V2 naming convention should look like this "War_Thunder_GamePlugin.dll".
    So as you can see the plugin updater is doing what it is suppose to.
    Here is the current SimTools v2 plugin for this game.
    https://www.xsimulator.net/community/marketplace/war-thunder-plugin.176/
    Take care,
  19. ACTIVE-GAME
    ACTIVE-GAME Member
    251Coins
    2DOF, 3DOF, AC motor, SCN5, SCN6, SimAxe, Motion platform, 4DOF
    with the latest version of the game, the latest plugin does not work, there is no telemetry data
  20. ACTIVE-GAME
    ACTIVE-GAME Member
    251Coins
    Today I tested War thunter with the old plugin for version 1.3 and it works great, but the new plugin does not work, there is no telemetry from the game!
