Ville Pesonen
War Thunder Plugin 2.3.1.1
SimTools V2 plugin for War Thunder
  1. the2jakes
    the2jakes Member Gold Contributor
    137Coins
    DC motor, Arduino, 4DOF
    Hi, same issue for me. With some planes I get no roll and pitch data (other inputs working). with other airplanes for example D-510, I get pitch but not roll data...
    Anybody found a solution ?
    154,849Coins
    +11,229 / 57 / -2
    One for @Ville Pesonen to consider.
  3. Ville Pesonen
    Ville Pesonen Active Member
    871Coins
    the problem with no pitch/roll data for some planes comes from the game itself. for some reason some of the planes just do not provide the data for those.
    the plugin pulls the data from http://127.0.0.1:8111/indicators
    Its been a while since I did anything with the plugin, but if I remember correctly the values for pitch/roll are pulled from "aviahorizon_pitch" and "aviahorizon_roll" and those are not available for every plane for some reason.
    the extra1/2 might do the trick for the planes that do not provide the pitch/roll data.
  4. Rodrox
    Rodrox New Member
    16Coins
    Hi, does this plugin enables the force feedback on the Microsoft Force Feedback 2 Joystick (on WarThunder)?
    154,849Coins
    +11,229 / 57 / -2
    Sorry no Rodrox, the plugin has nothing to do with FFB on the Microsoft Force Feedback 2 Joystick.
  6. polybasss
    polybasss Member Gold Contributor
    Burgos Spain
    155Coins
    It seems that there are new variables that are not associated with the artificial horizon
    http://127.0.0.1:8111/state -> pitch http://127.0.0.1:8111/indicators -> bank, turn
    You can still update the plugin to work with more planes
  7. Ville Pesonen
    871Coins
    It's been a while since I've been online here on Xsimulator and unfortunately at the moment I don't have the time to update the plugin. I've attached the plugin source code if someone would like to have a crack at updating the plugin to support the new data available from the game.
    In the zip file there's following folders:
    GamePlugin - Contains the source code for the plugin
    Vibethings - Some settings for Game vibe (It's been a while since I've done anything related to this plugin, so I cant remember what these are for)
  8. Larux
    Larux New Member
    Argentina
    - 1,235Coins
    Hello, the plugin does not take the new version of simtools.
    Someone with the same problem?
    154,849Coins
    +11,229 / 57 / -2
    If you mean SimTools v3 then everyone will have the same problem, as it is in beta for testing purposes and only a handful of plugins have been implemented.
  10. zutica1337
    zutica1337 New Member
    16Coins
    Why I cannot download this? xd
    154,849Coins
    +11,229 / 57 / -2
    SimTools v2 plugin access is via membership or forum activity coins, see the FAQs here: https://www.xsimulator.net/community/faq/coins-and-how-to-download-plugins.2/
    And related forum rules: https://www.xsimulator.net/community/threads/forum-rules.9527/
    SimTools v3 is in open Beta testing at the moment and introduces and integrated plugin repository for licensed installs, while not all plugins are available yet War Thunder is: https://simtools.us/plugin_library/
    SimTools v2 and v3 can be installed on the same PC and use the same license key.
