Question What exactly do the sliders in the washout filter do?
Discussion in 'SimTools DIY Version' started by Alexander Asner, Jul 21, 2018.
  1. alex928gt
    alex928gt Member
    409Coins
    Ok I'll post my settings tomorrow but they are currently very straightforward.
    Alex
    154,750Coins
    +11,196 / 57 / -2
    That would be great, as I suspect with the physical construction of your rig, and what I believe you want in terms of its responses, the required collective profile settings will be anything but 'straightforward'.
    I also suggest you start a specific thread, as this is really a question about how to best tune your specific rig and is getting off topic for this thread.
  3. Frada
    Frada New Member Gold Contributor
    69Coins
    2DOF, SCN5
    Good morning,
    for a 100mm SCN in traction loss how much can I put as a base in washout gain and return to start?
  4. yobuddy
    51,704Coins
    This is always a good place to start buddy.
    If the return is not fast enough, adjust the top slider.
    While adjusting the bottom slider will make the output more or less active.
    Hope this helps.
    Take care!
  5. Frada
    69Coins
    2DOF, SCN5
    to not feel the return to the center I have to set the return to -69.
    The gain is at the max.
    am I doing it right?
    Thanks for help
  6. yobuddy
    51,704Coins
    Please make sure you have captured Max/Min values for the corresponding input from the game.
    I suggest setting the gain and return to 1 and 1, and adjusting the Max/Min value till you get it somewhat working, and then re-tune it in as needed with the gain and return sliders for the filter and you should be good to go.
    Take care!
  7. Frada
    69Coins
    2DOF, SCN5
    Hello, I can't do a tuning center on Richard Burns rallye. I capture, I roll but no data changes and is saved..... can you help me?
  8. yobuddy
    51,704Coins
    Sure, PM me buddy...
  9. Frada
    69Coins
    2DOF, SCN5
