what hbridge will work
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by terry wells, Jun 22, 2014.
  1. BlazinH
    16,700Coins
    I doubt it would fail due to under powering also but thought it could be a possibility!
  2. terry wells
    terry wells Active Member
    retired military
    minnesota USA
    717Coins
    3DOF, Arduino
    How many amps will a 12 vdc wiper motor draw? does any body know. Is there a way that I can measure the amperage with a multi meter? And could not having my ground isolated cause my monster board to go bad?
    Terry W.
  3. RacingMat
    21,088Coins
    To measure your current while feeded with PWM, you need a "true rms" multimeter.
    Best has got "max" and "mean" values!
    Has I haven't such a device, I don't know the answer...
  4. bsft
    I found with wipers they car draw a lot of power. I used wipers from larger cars in the beginning and I had set my max current in the JRK at 23 amps, but the motors could have been pushed a lot harder.
    Normally we run the motors at stall current, which is usually 2.5 - 3 times the rated current. But they can drain more if worked hard enough.
    To actually measure a draw of current in motion, you could put a shunt across the power line and get an average reading from a multimeter.
  5. auryza
    auryza Active Member
    Lithuania
    4,339Coins
    2DOF, 3DOF, Arduino
    Hi Terry
    My one motor from nissan micra drain 6 - 7 amps . Overall per four motors i have 20 - 28 amps in very hard moments . So it's not so much .I would say that wiper motors can drain something from 6 to 10 amps . I using cheap power supply from PC 750 w . It's enough to keep my sim in running. So ,you can count how much power you need for your needs . Take maximum of power 10 amps . if you have four motors it's 40 amps on 12 volts . 480 watts of power supply ,But its theoretical only ! allways take more 30 - 50 % so , should be 600-900w power supply for 40 amps.
    If you gonna use motors on metal frame you have to isolate motors ground ,if will not ,it can cause motor drive damage , but if frame is wooden you can leave how it is .
  6. terry wells
    retired military
    minnesota USA
    717Coins
    3DOF, Arduino
    Hello Auryza, Thanks for the information. I will purchase a PS that will give me that power.
    Terry W.
  7. RacingMat
    21,088Coins
    if you only need a rough approximation:
    take not less than 47A @12V for 2 smolka motors
    it's fine but the limit is close!
