What kind of printer do you use?
Discussion in '3D Printing' started by bruce stephen, Feb 12, 2016.
  1. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    3DOF, DC motor, Arduino, 6DOF
    I must say, you got 3 for the price of mine.
  2. MarcoMade
    MarcoMade Active Member
    italy
    157Coins
    ahahhaah is the name of the team that had adapted the marlin firmware on the anet a8. before marlin support became official :)
  3. SoftKitty
    SoftKitty Member
    Engine engineer
    Nantong, Jiangsu, China
    - 140Coins
    AC motor, 6DOF
    I use a JGAURORA A3S, a Chinese brand model, for about 310USD
    dimension capability:205*205*205mm
    By that I've printed self-designed steering wheel adapter and pedal shims
    Recently I built a new home for it, on top of my lavatory!
    • Funny Funny x 2
  4. Spiros K
    Spiros K New Member
    Freelancer
    Melbourne, Australia
    137Coins
    AC motor, Arduino, 4DOF
    modded ender 3 pro
    getting really good prints
    upgraded the board, hotend and other small bids and pieces.
    Using Cura to slice and have managed to get good settings.
    I change settings depending on what I am printing.
  5. sagrada737
    sagrada737 New Member
    Retired from the computer industry
    Las Cruces, New Mexico USA
    247Coins
    I have two Creality 10S Pro 3D Printers. As some of you may know, these printers are fairly inexpensive, and the quality control at Creality is not known for being the best. However, despite my receiving both printers with screws loose within the shipping box, I expected this, and was prepared to carefully search the shipping box for the few tiny screws and nuts that had fallen off during shipment. Not to start out negative... I would like to state that the Creality 10S Pro is quite a value for the money.
    I typically use a 0.6mm nozzle, and print mostly with PLA, PETG-Carbon Fiber, PLA-Carbon Fiber, and Nylon-Carbon Fiber. I have found that on the practical side of things. it is very difficult to predict dimensional tolerances with these 3D printers, as it varies depending on the type of part you are printing, the Filament material, speed and other settings.
    I use both FreeCAD and Fusion360 for the CAD design. I process STL files in CURA. I have experimented with quite a few print bed materials, but what I like the most, and have found to work the best, it a 0.125" think mirror tile and/or a mirror tile (good) with a Kapton tape surface (best). I use the typical Elmers glue stick for bed adhesion. If I print with ABS, then I make up an ABS/Acetone slurry, which works well.
    My application is typically making small parts and brackets, etc for my full-scale B737-800 flight simulator project with 6dof Motion Platform. 3D Printing can be a life saver when you need a special part that is not dimension critical, and where high strength is required.
    Mike
  6. sagrada737
    247Coins
    Below is a photo showing my Creality 10S Pro 3D Printing area of my shop...
    Mike
  7. vietdn
    vietdn New Member
    54Coins
    2DOF, 3DOF, Motion platform
    I have a heavily modded cr10s and planning to buy a resin printer in the near future. Really want to see how the new mono's perform.
  8. Andrew Bird
    Andrew Bird New Member
    Christchurch, New Zealand
    205Coins
    3DOF, AC motor
    I'm running my old but trusty Anet A8 with E3D clone hotend and remote extruder. Upgraded to a server power supply and in an enclosure for printing ABS. Only had one real issue since first setting it up and that was the power connector on the external mosfet came loose causing it to reboot during prints. Just had to strip the wire and re-tighten and all is happy again. It will be back into heavy use shortly as I need to print SFX-100 parts and will use ABS for that as well.
  9. Zippo246
    Zippo246 Member
    Sydney, Australia
    158Coins
    I'm using a Creality Ender5. Upgraded the board to Creality 1.5, axis movement is now silent. Bear in mind you can get better boards now for the same price. Always on a learning curve....
  10. Zippo246
    Zippo246 Member
    Sydney, Australia
    158Coins
    For the failed prints it saves time I guess...
  11. czgui
    czgui Member
    - 110Coins
    My printer: Anycubic i3 Mega S, it works well.
  12. Onii77
    Onii77 New Member
    Programmer
    North Carolina, USA
    158Coins
    AC motor, 4DOF
    Add another CR10S, currently printing off a SFX100 bump-stop while debugging a wall separation issue :confused:
  13. hallacathy
    hallacathy New Member
    24Coins
    Joyrider
    CTC Flashforge and a Dreamer 3d
  14. Brandon voils
    Brandon voils New Member
    CNC programmer /Engineer
    37Coins
    I use a creality cr-10 . It is a great printer for the price and has a heated bed that is plenty big enough to print just about anything you would want to add to you sim .
  15. Captain Jack
    Captain Jack Member
    - 26Coins
    I've got a Wanhao Duplicator I3. The hotend motor is a bit weak, which limits the speed of the print but other than this, it has been a work horse. It printed 6km of filament without any issues.
  16. Virusao
    Virusao New Member
    43Coins
    Hello, I have a x1 artillery to which I have made some modifications such as the autolevel and some reinforcements in the structure. I also changed the hotend and put a direct drive to avoid traffic jams.
    I bought the printer at the start of the Covid-19 to print protection screens.
    I usually use pla and petg, although I would like to start an abs.
    I am practically an expert in disassembling the printer, so for any questions that I can answer, here I am.
  17. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
  18. Pascal Thanheiser
    Pascal Thanheiser New Member
    30Coins
    i have 3 Sunlu S8 plus and one Sunlu S8. never had any problems and they printing and printing and printing. cheap, big and easy.
  19. OzzyO
    OzzyO New Member
    ARGENTINA
    - 25Coins
    2DOF, 3DOF, DC motor, AC motor, Arduino, Motion platform, 4DOF, 6DOF
    I have my own design working. it like a old prusa but maded with steel (1 1/2x 1 1/2") welded.
    Its the best because its very stable and i dont need recabrilate the bed for longs times.
    I have 2 machines 30x30x30cm and 20x30x30cm.
  20. ba114
    ba114 New Member
    190Coins
    DC motor
    Prusa MK3S+
