What kind of printer do you use?
Discussion in '3D Printing' started by bruce stephen, Feb 12, 2016.
  1. Troy
    Troy New Member
    Australia
    346Coins
    I use a wombot xl its been a good printer and worked first up after I built it. It has a good build volume of 250mm by 250mm by 330mm a heated bed .
  2. TheAnswerIsAlways:
    TheAnswerIsAlways: New Member
    Ontario
    243Coins
    I bought a Prusa i3 kit from Folgertech LLC. It was cheap and have had it almost a year. Took a bit of troubleshooting to set it up, but it gets the job done! Has a heated bed and I can print up to 8x8" and 7" tall
  3. JigoroS13
    JigoroS13 New Member
    Thailand
    255Coins
    I use Flashforge Dreamer i use it for 2 Year it helpfully on my DIY work.
  4. bruce stephen
    general contractor
    michigan
    9,115Coins
    There are so many variations. Tons of manufacturers.
  5. Nick Moxley
    17,057Coins
  6. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Haveing a measurement probe is awesome, self leveling should be standard on all printers. Thats the biggest pain in the ass to my POV
  7. Nick Moxley
    17,057Coins
    Not exactly sure what benefit the Measurement probe offers And i can assume that self leveling would be handy not having to screw around with that. But the question still remains, Is the MK2 worth the extra coin.
  8. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Thats what the measurement probe does, it goes to certain coordinates, usually 4 or 9 and the the self leveling happens one of 2 ways....the plate adjusts in the corners or its dont in software which uses your steppers on the y axis to compensate for a high or low spot.
    • Informative Informative x 3
  9. paulg100
    paulg100 Active Member
    Bristol UK
    1,373Coins
    3DOF, DC motor, 6DOF
    Hi All
    I'm thinking of pulling the trigger on a printer at the minute to help with parts for my sim
    Was thinking about the new duplicator i3 plus that's just released. Money is tight at the minute so that's probably top of my budget.
    http://www.ebay.co.uk/itm/Wanhao-I3-Plus-3D-Printer/222201963657?_trksid=p2045573.c100033.m2042&_trkparms=aid=111001&algo=REC.SEED&ao=1&asc=35377&meid=f01532393c6e40659af5558636155430&pid=100033&rk=5&rkt=8&sd=262466591052
    @wannabeaflyer2 I noticed you bought the duplicator i3, how that going for you,
    how much of a pain is it not having an auto leveling bed?
    My other alternative I thought is a prusa i3 mk2 kit but its a bit outside my budget at the minute and TBH id rather just get on with printing rather than messing about with a kit right now.
    (the sim building is already taking all my spare time)
    http://shop.prusa3d.com/en/3d-printers/59-original-prusa-i3-mk2-kit.html
    thanks for any advice
  10. wannabeaflyer2
    london uk
    8,350Coins
    Hi @paulg100 I have to say bang for buck my Wanhao printer does what it says on the time , have had some great parts made form this machine and any that failed was due to my fault not the machine so far , <£300.00 and great performance , ease of use etc , Once you've mastered the bed levelling is easy , maybe one day i'll do a Auto bed level upgrade but for now its fine . My only gripe would be with the supplied Cura software ( excellent and very user friendly, but I'm having issues trying to talk to printer via the software , if I use Repeiter there's no problem , the fix apparently requires me to open the Control case , but I'm releuctant to do that yet ( warranty would be void I guess ) ...other than that I'm more than happy how quickly I had the machine up and running, and knocking out great parts ..
  11. paulg100
    Bristol UK
    1,373Coins
    Great thanks for the feedback,
    I actually bit the bullet last night and ordered a new duplicator i3 plus for £399 so hopefully that works just as well as the original duplicator i3.
    I expect some loose screws etc on delivery and see theres already some issues with the plate bearings in this model but its easy and cheap to fix.
    Once i have some spare money ill probably buy simplify 3d.
    did you take a look at this mod?:
    or updated version.
    Its probably one of the first things ill look at adding.
    EDIT: good news, the duplicator I3 plus already comes with a ported fan for the nozzle opening
  12. Nick Moxley
    17,057Coins
    So decided on a i3 Mk2.....anything i should pick up while i have the order in the cart ? should i order a couple rolls or will one suffice for now ? Looking at the Fancy 20% carbon stuff.....is it worth 50$ ?
  13. paulg100
    Bristol UK
    1,373Coins
    Was doing some reading on that, it seems that particles and fibres are two different things and that to be effective the mix should have fibres at least 7mm long to form the lattice.
    these carbon impregnated filaments are particles rather than fibres, so marketing hype??
    like sprinkling pixie dust into some resin and expecting it to do something.
  14. Nick Moxley
    17,057Coins
    Ah icic, thanks for the heads up Paul,
    What would be the strongest most user friendly material to print overall ? Whats your go to filament you prefer ?
  15. paulg100
    Bristol UK
    1,373Coins
    There's better people to ask then me :) i dont even have a printer yet (being delivered this week).
    Spent quite a bit of time reading up on it though. Theres some good utube vids going through the different properties and doing tests etc, compressive force, ductility, brittleness etc. For structural stuff and for ease of printing id say the newer gen PLA's seem to be good? stronger than ABS but still print like PLA and allot more eco friendly than ABS.
    for gears and parts with frictional wear nylon looks real interesting.
    First things ill be printing are pot shaft couplers and brackets, then i need mounts for gearstick, jotstick etc and also a box to house some switches etc.
    The gearstick mounts need to be fairly strong so im hoping to try one of the newer gen pla's for those, unless anyone has a better suggestion.
  16. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    I printed these two models with PLA and they are solid.
    The Premier League trophy is hollow but very rigid. The FA cup is 50% infill and heavy and hard.
    Colours used:
    Black
    Silver
    Gold
    Green
    All PLA.
    I've not printed with ABS, but have to say I've not been able to find anything I needed to print that PLA was not useful for.
  17. Nick Moxley
    17,057Coins
    Picked me up an Prusa i3 Mk2
    I did have a slight issue with my first BIG print, Tho i think it was a power glitch as there was a rather intense rain storm about the exact time it cut out (I was out at the time so dont know 100% what happened) I did the Test Tree frog in .100 as well and it turned out Awesome. Haven't tried the .050 yet.
    but here's the re print as a headless buddha just wasn't gonna cut it. First one is .100 layer 10% infill with 4 walls which proved to be INSANELY strong, I can stand on him No problem, so Version 2 i went with .100 1% infill and 2 walls thick, 13 hr print vs 18 hr(guesstimate) print
  18. Nick Moxley
    17,057Coins
    Being able to print stuff like this, Is a Game Changer lol
    1 Corvette wheel comin up.
  19. robotdigg
    robotdigg RobotDigg Equip Makers
    24Coins
    2DOF, 3DOF, 6DOF
    I am enthusiast of 3DOF n 6DOF:)
    Either Delta Robot 3D Printer or Scara 3D Printer
  20. Artois
    Artois New Member
    Hinesville, GA
    246Coins
    I have been lurking this forum for a while and now I am finally ready to pull the trigger on buying a 3D printer. I have been doing my research and read most of the buy guides but not an expert of any sort. I have been looking at this Prusa model and was wondering if there is anything I am missing and if it would be a good pick for someone starting out. Seems like a good price point with most of what you want to look for from what I have read. I also like the larger print bed.
    Any help is always apprecaited.
