Winch Motors?
Discussion in 'Motor actuators and drivers' started by boosted-lt1, Jan 21, 2012.
  1. eaorobbie
    20,506Coins
    Need to check that they are reversible on mine there was a rachet key that stoped them from reversing , so I just remove it and the gearing could spin both directions, some don't have this but I think @Historiker had a way around that but these look simular to the units that I first used in '09. Heaps of torque only issue was with power off they rolled back to the bottom. Easy to add a gear and 3 turn pot too or can be setup with single pots like this.
    Partion the swear word this running xsim2 - they are noise too but it is sitting on a large empty box, oops.
    In Action
  2. billo2404
    billo2404 Member
    Roma, Italia
    1,236Coins
    AC motor, 6DOF
    grazie eaorobbie, preciso come sempre. valuterò bene le possibilità prima di acquistare :thumbs
    Thanks eaorobbie, accurate as ever. I will consider well the possibilities before buying :thumbs
  3. eaorobbie
    20,506Coins
    Just to add to conversation , Im investigating to use the Velleham K8061 which will allow us to control 3 sabertooths for the possibility of running 6dof simulator all of one controller, $95 bucks on ebay.
  4. billo2404
    billo2404 Member
    Roma, Italia
    1,236Coins
    AC motor, 6DOF
    è una bellissima notizia, ne avevamo già parlato con kevin che aveva trovato questa scheda.
    con un app dedicata sarebbe ottima per chi vuole realizzare 3,4 o 6dof con una sola scheda.
    Seguirò lo sviluppo con molta attenzione :thumbs
    is a wonderful news, we had already talked to kevin that he had found this Board. with a dedicated app would be great for those who want to realize 3,4 or 6dof with one card.
    I will follow the development very carefully :thumbs
  5. -kevin-
    -kevin- Fast e Furious
    Termo Tecnico industriale
    128Coins
    2DOF, 3DOF, DC motor, SimforceGT, 4DOF
    Si e proprio una bella notizia usare 4 motori o 6 e non essere più limitati con una sola k8055 con 2 motori
    Se tutto questo sarà possibile e solo grazie al duro lavoro che svolge @eaorobbie.:thumbs
    Volevo precisare una cosa per chi ha intenzione di aquistarla : la k8061 e da assemblare cioè saldare tutti i componenti elettronici... invece la VM140 che è la stessa scheda... ma è già assemblata http://www.velleman.eu/products/view/?id=369162 ;)
    It is good news and just use 4 or 6 engines and no longer be limited to a single K8055 with 2 motors
    If all this is possible only thanks to the hard work they do eaorobbie. :thumbs
    I wanted to clarify one thing for those who want to aquistarla: the K8061 to assemble and weld that is all electronic components ... but the VM140, which is the same card ... but it's already assembled http://www.velleman.eu/products/view/?id=369162 ;)
