wind simulator
Discussion in 'DIY peripherals' started by bruce stephen, Apr 1, 2016.
  1. SilentChill
    20,603Coins
    Easy enough then if you not gonna spend £10 on a Ard and MM all you have to do is just use one of @eaorobbie fan example codes and create your own for JRK's it's not too difficult to do.
  2. MarkusB
    4,215Coins
    Well, it's not the money. It's just that I am completely satisfied with the JRKs and their simple setup. So I will look for the fan examples you mentioned.
  3. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,950Coins
    @SilentChill ... if I'm useing the Ard. With the SMC3 code in my sim and I have an extra unused motor in the arduino ... can I port the speed value from the game dash to that motor ?
    Or do I have to add a spicially coded one ?
  4. bruce stephen
    general contractor
    michigan
    9,115Coins
    @speedy you cant run two sketches at the same time on one arduino uno.
  5. speedy
    Alexandria , Egypt
    7,950Coins
    Ok nice ... but how the arduino will handle the communication speed defference or remap the output pins then ?
    Plus you can use the SMC3 PID for more wind simulation accuracy and me have a ready to go setup for 1Hp AC motor big blower that can give enough detailes for my skleleton :D .
    Edit : Maybe it is a game dash related additional option that needs to be tested as "Dash" ouput not "Axis"
  6. Diego Amaral
    Diego Amaral Member
    Rio de Janeiro
    98Coins
    Does the game dash work with DIY license?
  7. SilentChill
    20,603Coins
    No
  8. Diego Amaral
    Diego Amaral Member
    Rio de Janeiro
    98Coins
    Thanks! :(
  9. paulopsx2
    paulopsx2 Active Member
    brasil
    648Coins
    anyone with list of all games suported speed "wind"? asseto corsa for example? ( SOLVED )
    ok, I just put asseto, no MATH need on command; the dash assumes driving speeds at KM/H. Just on No limits 2 stay on m/s.
  10. paulopsx2
    brasil
    648Coins
    someone have a wind ( speed data ) for project cars?
    154,400Coins
    +11,181 / 57 / -2
  12. paulopsx2
    brasil
    648Coins
  13. paulopsx2
    brasil
    648Coins
    avengas post dont refer to wind... i use standard pc plugin, and no speeds sends to game dash.. at the same time, on plugin download, no point about speed data too.. only basic data see:
    "" Motion data:
    This plugin provides pitch, roll, yaw and surge, sway, heave acceleration and traction loss.
    DashApp Data:
    Additional values for instruments are feasible, yet not implemented. ""
    so.. i take the UDP version... more complete i think
  14. paulopsx2
    brasil
    648Coins
    guys.. new progress here.. filtering some inductors !! result are 99% non-tone on excution ! i uploading some videos now.
