value1
X-Plane V10 Plugin 2.0.2.0
SimTools game plugin for X-Plane V10
  1. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,900Coins
    DC motor, 6DOF
    Real life situation in 737-800
    iPhone positioned on the floor.
  2. hexpod
    berlin
    7,900Coins
    DC motor, 6DOF
    @yobuddy
    Imagine you are siting on a chair. You are exercising a pressure (weght) on it, if I tilt this chair 30deg to the side you will feel that you are falling to the side.
    I can insure you that the pressure on your butt (weight) will be half in this scenario.
    Is this not the most natural fenomenon that when you bank, the local heave (your chair) is modified ???
  3. Dirty
    All the way up front.
    7,980Coins
    :) Please, forgive me guys if I smile, but you are exactly making my point :) even if not intentionally :)
    If you hold the phone in one orientation (1st half of the video) then you will have accelerations of say...
    x = 0.00 m/s^2
    y = 0.00 m/s^2
    z = 9.81 m/s^2
    If you then tilt it into another orientation, or move it around (2nd half) you might get accelerations of say...
    x = 0.00 m/s^2
    y = 9.81 m/s^2
    z = 0.00 m/s^2
    ...or anything in between, depending on the angle of tilt.
    So, if I wanted to play devils advocate here I might say that "this rouge gravity component messes up my nicely planned motion measurement activity and should therefore be cancelled out mathematically" :)
    .... but instead I would like you guys to see the underlying hidden truth (for lack of a better expression) that in the first half of the video @hexpod was actually pushing against the phone from below while it was laying flat in his hand. If you then tilt it up vertically, you are actually pushing against it from the back (from the phones perspective). In both cases, as well as in any other case there ACTUALLY is a force acting on the vehicle (phone) and a pilot/driver/bacterium inside the phone would feel being thrown over to one or the other side.
    If you go through a banked corner, you will have centrifugal force (like in any other corner), only this time because of the bank angle a component of that force sin(bankangle) will act along the vehicle vertical axis. Are you sure that this couldn't have been a perfectly plausible scenario?
    Maybe it even was a case of a sim that uses accelerations without the gravity component or any other physically incorrect mathematical construct. @pmvcda told me about such a driving sim. If that was the case, then yes of course that is what we will have to work with and make the best of it. But X-Plane does provide proper accelerations (aka containing the gravity component) and I can tell you that in X-Plane whenever there IS an acceleration value being shown, there actually IS a force acting on the vehicle.
    Dirty :)
  4. Dirty
    7,980Coins
    That's hilarious!!!! Great!!! I can imagine you sitting in the plane with the two phones :) And it is nicely time-matched between the video and the data. Thanks!
  5. yobuddy
    51,747Coins
    Try it, it will still show 1g no matter what you do as its modeling the earths gravity from the game.
    And it will come off as acceleration as you plane goes into this position.
    I'm saying when you point your nose up in the air, you will get acceleration data if 1g no matter what as its modeling gravity in the game.
    Yes, because of gravity in real life, there is no reason to emulate it again from the "game" as i see it.
    Yes, this is because of the 1g gravity here on earth.
    So why would we need to model it again from the game?
    Take care,
  6. Dirty
    7,980Coins
    In X-Plane? Are you sure? Because that would be a bug the size of Texas :) I can't confirm right now, because I will be windsurfing in Egypt for the next three weeks, but if you want to find out, here's what you need to do:
    1. Take a glider aircraft and position it way up in the air (10.000ft)
    2. Show the "motion platform stats" data tab and find the longitudinal acceleration (should be "Accel-Z").
    3. Push the nose down to gain speed. I mean A LOT of speed!!! ...and then some more...!
    4. Pull the nose up into the vertical quite aggressively without breaking the wings off.
    5. Hold a pitch of 90° as good as you can.
    6. Observe the longitudinal acceleration.
    As there is nothing pushing the aircraft, and very little pulling on it (only a little drag) the longitudinal acceleration should initially show a minimal deceleration (aerodynamic drag) but as the airspeed bleeds off it should be pretty close to zero. Certainly not close to 1G.
    Could you try this out?
  7. hexpod
    berlin
    7,900Coins
    DC motor, 6DOF
    Maybe here is the point of wrong assumption.
    At the starting point the +1G is not there anymore because it’s washed out. (No additional emulation) - the platform is centered.
    Than, we are not adding it twice, (emulating again) it is subtracting this 1G once a tilt occurs.
    Again, of course we are talking here about the scenario where the Euler angles are NOT in use or where they are strongly washed out.
    Best.
  8. hexpod
    berlin
    7,900Coins
    DC motor, 6DOF
    Gravity 0 in xplane exists as well as in real life in some circumstances. lol
  9. hexpod
    berlin
    7,900Coins
    DC motor, 6DOF
    I am glad that some developers like @pmvcda , instead of willing to cancel the gravity component want to add it to the titles where it is not present.
    To all developers, @yobuddy @value1 , to all simmers: please guys, after more than 10 years of simtools existence, maybe it’s time to give another try and reconsider your cueing approaches.
    Please give a try, don’t tilt your platform with Euler, just try to tilt it with velocities and the gravity component whenever you have a chance to access this kind of telemetry.
    With new tools like washout, smoothing etc, simtools
    finally gives us the possibility to push our hobby on another level of realism.
  10. hexpod
    berlin
    7,900Coins
    DC motor, 6DOF
    I am on the last beta and still see a small bug in surge and sway while playing back the reply.
    I’ll try to write to Austin asking for a double check
  11. yobuddy
    51,747Coins
    If you use washout for heave, then yes it will center.
    But then you have no choice but to use washout for heave.
    And that does not fix the problem I'm tying to point out.
    Slowly tip 90deg to the side, and heave will change just because of the 1g gravity thing and sway will now have the 1g.
    So just by tipping to 90deg, if you were on a sway slide table, you would slide toward one side, as if there was a gust of wind or something.
    Washout will center the sim if used, but it does not fix the problem of false cue-ing is all I'm trying to say.
    I still don't think you fully understand the problem I'm trying to show.
    Please turn off all washout on your sim, and then slowly do barrel rolls, it may help it stand out some more and show what I'm talking about.
    Please note that I'm not running XPlane, but I recognize this problem so I thought I would jump in the chat about it.
    Take care,
  12. hexpod
    berlin
    7,900Coins
    DC motor, 6DOF
    First of all, thank you very much for taking part in this discussion. I think the communication is the real force of this community.
    Yes, entering in the edge knife flight will transfer 1G from heave to sway. This steady sway is washed out on the sway dof and the tilt coordination (sway on roll) which is NOT washed out will take over, tilt the platform and keep it tilted.
    The platform will sink for a short while and bank, transfering the pressure from my butt to the side of my body.
    What appears to you false (unnatural) in this scenario ?
    Of course we cannot tilt the platform up to 90 deg but still, banking 25 deg. through the gravity component which went to sway (actually roll in our coordination channel) is better than nothing.
    I am not giving up. I will keep searching where you think the false cueing occurs.
    Thank you for being concerned by the discussion.
    Best
  13. hexpod
    berlin
    7,900Coins
    DC motor, 6DOF
    It can be, there is a better approach for this scenario (than the one I described above).
    For the moment I am not aware a better one exists but If you ( @yobuddy of someone else) propose an alternative I will be more than happy to try it out.
    I doubt linear accelerations (without gravity) + Euler angles could satisfy us more than accels with G and velocities.
    We all want to get a cool motion out of our 6-dof rigs with a minimum amount of false cueing.
    Cheers
  14. Dirty
    7,980Coins
    Spot on! :thumbs
    Washout needs to be on Accel_Vert, Accel_Lon and Accel_Lat. The tilt-coordinartion is not washed-out. Indeed, only a part of the sidle load can be cued, but that's what we will have to live with.
    Well explained!
  15. hexpod
    berlin
    7,900Coins
    DC motor, 6DOF
    I think I do understand but I disagree :)
    I did the barrel rolls tests you are asking for.
    I am ready to change my mind if someone comes with logical arguments and will propose a better solution.
    I dont have time to fine tune it but I think the main idea of accel+G / angular veloc. is there.
    test made using SimTools filters with hexpod plugin.
    @value1 , @Dirty , @yobuddy , @Thanos , @pmvcda , please guys, list what appears to you wrong, false in this approach.
    thank you
  16. hexpod
    berlin
    7,900Coins
    DC motor, 6DOF
    Yes that’s right.
    Austin just prepared a test build for us adding needed telemetry in replay.
    @Psionic001 , I PM you the link for download if you want to test it.
  17. Psionic001
    Psionic001 Active Member Gold Contributor
    Sydney
    997Coins
    Motion platform, 6DOF
    Cool. I’ll download and give it a try.
    Thanks.
  18. yobuddy
    51,747Coins
    That was not the topic we were discussing thou, I'm Only talking about accelerations (with gravity) vs accelerations (without gravity), the floating 1g.
    I'm also considering all simulator builds and not just 6dof sims.
    (But that really does not matter as I believe it's still a miss cue.)
    The floating around 1g.
    The fact that you have to use washout to sort-of "fix" the problem.
    (The problem is still there with washout btw,, its just muffled out some with washout is all)
    To be honest, I really don't know how to say it any better than I did yesterday.
    Take care,
  19. Dirty
    7,980Coins
    Hey @yobuddy
    I promise, if I ever make it back into PDX we will be going for a beer. Equipped with a pencil and a huuuuge stack of paper :)
    I think there are two key points of misconception (correct me if I'm wrong)
    1. You think that if you don't cancel out gravity in the exported data, you will be applying it twice.
    2. You think that gravity is a force.
    Please embrace (just for a minute or two) the idea, that gravity is NOT a force, but instead just a side-effect of the curvature of 4D spacetime. We, in this very moment, are all racing through the fourth dimension (time) at the incredible speed of 1 second per second (kinda). But since the ground beneath you will not allow you to go "straight" through spacetime, you are feeling the centrifugal acceleration of that curvature. It's an illusion, because you are so used to perceiving the world from the perspective of an accelerated frame of reference. Kinda like Coriolis force is only an apparent force that only exists in the rotating frame of reference from which you measure it.
    As simple as possible:
    Whenever there are accelerations exported out of X-Plane (motion platform stats), there actually IS a force present causing that acceleration. Ignoring that force means ignoring something that the occupant feels. That "floating" 1G has a cause. Find it! Understand it! Use it! Cue it to the user! It's your friend, not your enemy.
    Dirty :)
  20. Dirty
    7,980Coins
    That looks plausible to me.
