SimTools v3 Public Beta
  1. lysa elec
    lysa elec LYSA ELEC
    16Coins
    can you help me thanks ,
  2. notfasteddy
    notfasteddy New Member
    48Coins
    Pretty new to Simtools and having a few issues. I have looked in what I thought were the relevant threads but could do with some guidance.
    I have a 2DOF rig and got it running with simtools on LFS. However settings in the tuning center do not stay saved.
    I then changed to MSFS 2024 which is why I built the rig in the first place.
    Now I am having different problems. I posted in the MSFS 2024 thread but Noorbeast suggested I post the issues here as the maybe related to simtools v3 beta, see here: https://xsimulator.net/community/threads/msfs-2024-plugin.19114/page-2#post-259311
    Firstly I cannot exit simtools the normal way, I need to use task manger everytime to shut it down it seems to keep running in the background.
    But my main issue now is that I cannot get the MSFS 2024 plugin to run my rig. Works ok on LFS but in MSFS the rig starts up but none of the controls make any movements, I can see the yoke moving on the screen and the numbers moving (randomly) on the input line of tuning centre in capture mode but nothing moves.
    I posted all setting in the MSFS thread but can do so again here if required.
    Saving settings also does not work as well in MSFS
    I also had a number of windows crashes when in capture mode with MSFS running.
    Appreciate any assistance.
  3. lysa elec
    lysa elec LYSA ELEC
    16Coins
    i have allways the problem
    In the options menu, every time I check "open automatically with game launchers," the box is unchecked every time I restart my computer.
    What's happening?
  4. notfasteddy
    48Coins
    Just a short update on my issues with MSFS2024. I seem to have resolved the crashes as they are related to the AMD Raedon driver setting after an update.
    Other issues running with SIMtools as mentioned before still exist although I am trying other things.
  5. yvsbvn
    yvsbvn New Member Gold Contributor
    - 329Coins
    3DOF, SCN5, SCN6
    I use Simtools V3. The Dirt 3 plugin does not seem to allow the use of Dirt 3 Complete Edition. When the plugin starts, it redirects to a base version of Dirt 3 that is not installed on my PC. This base version no longer works and has been replaced by the complete version. Selecting the directory containing the game's executable file still prompts for the installation of the base version of the game.
    C:\Program Files (x86)\Steam\steamapps\common\DiRT 3 Complete Edition.
    Any ideas on how to fix this?
    Thank you!
  6. X.STTONER
    X.STTONER Sttoner
    business manager
    lima
    236Coins
    2DOF, 3DOF, DC motor, AC motor, Arduino, Motion platform, 4DOF
    Hi, I have a question. I've checked the posts and it seems the DIY license can be used in version v3, but there were some issues.
    My question is, have these problems been resolved?
    If I use my license in v3, will I be able to continue using it in v2?
    154,768Coins
    +11,200 / 57 / -2
    Specifically what problems are you referring to?
    If there are any problems experienced then post them and related details to this thread for resolution.
    You can install both v2 and v3 on the same computer using the same license.
  8. 204flightsinmotion
    204flightsinmotion Member
    227Coins
    So I have my rig all setup and testing properly in smc3. I build a motorcycle sim with an actual Kawasaki ninja. When I play motogp18 for some reason whenever I get into a crash or even bang a wall and don’t even crash the motors start pulsing and don’t stop I have to unplug the arduino usb to fix it. Super frustrating. I’ve tried putting crash detection on disable as well as turning it on with the same outcome. Any assistance appreciated
  9. notfasteddy
    48Coins
    Following on from my previous post. I reinstalled Simtools V3 beta and reconfigured my rig and FS2024 now works with my rig.
    However as mentioned before my configuration settings on max min tuning do not save in either LFS or FS2024 which means I have to reset them every time before I use the sim.
    Ed
  10. kalbasator
    kalbasator Active Member
    Kazahstan, Almaty
    170Coins
    3DOF, DC motor, Arduino, Motion platform, 4DOF
    Hi! I have a question about parking mode:
    For example, I completed a special stage in Dirt Rally 2.0.
    Then my friend wants to complete the same special stage. What will the Sim Rig do after completing the special stage? Will it enter parking mode?
    So I can easily exit the Sim Rig and free it up for my friend...
    Or does parking only work when I exit the game?
  11. yo-hi
    yo-hi New Member
    28Coins
    I cannot get any motion/telemetry from DCS in SimTools v3. I have read through past threads and tried suggested fixes, but the issue persists.
    Current Status:
    • Export.lua: Exists in the correct DCS Scripts folder (Image 1 attached).
    • File Content: Seems correct (Image 2 attached).
    • UDP Test: No data received when checking with a UDP listener (Image 3 attached).
    • Other Sims: MSFS2020 and racing sims work perfectly.
    • SimTools Version: v3 only (never used v2).
    My Question: I suspect a conflict with other Lua files in the same folder.
    • Does anyone know how to isolate/identify a "bad" file causing interference?
    • Any advice on how to resolve such conflicts?
    Thank you in advance for your support.
  12. yo-hi
    yo-hi New Member
    28Coins
    The issue is now resolved. I found that when installing the DCS plugin, the export.lua file was automatically placed in the Scripts folder within the DCS installation directory.
    However, it didn't work until I moved the export.lua file to the following path:
    C:\Users\[Your (User Name)]\Saved Games\DCS\scripts
    If you don't have a "scripts" folder there, you will need to create one manually. Once I moved the file, everything started working perfectly.
    I’ve been struggling with this for a week, and I finally figured it out today—on my birthday! Thanks for the support.
  13. niki71711
    niki71711 New Member
    6Coins
    Hi, does anyone have a fully working configuration in SimTools v3? I can't get the Arduino to work. Can someone please help with Asset Corsa?
    154,768Coins
    +11,200 / 57 / -2
    Getting the Arduino to work is required before messing with SimTools, please start your own dedicated thread here and explain what code you are using, what hardware and post pictures of all settings: https://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
  15. Gerardo Rivera
    Gerardo Rivera Member Gold Contributor
    116Coins
    After updated to windows 11 lost the movement of the rig on Prepar3DV5 , MSFS2020 and FSX
    So far deleted and reinstall the plugin, Repo Njmotions, simconnect MSI10.0.62615.0 still no luck
  16. Joe Cortexian
    1,640Coins
    I am trying to get the latest "EA Sports WRC" working. Plugin install was smooth. SimTools indicates its attached to the game when running but there is no motion. Here is an excerpt from the telemetry config.json file:
    "packets": [
    "structure": "wrc",
    "packet": "session_update",
    "ip": "127.0.0.1",
    "port": 20777,
    "frequencyHz": -1,
    "bEnabled": false
    I changed this to:
    "packets": [
    "structure": "wrc",
    "ip": "127.0.0.1",
    "port": 4123,
    "frequencyHz": -1,
    "bEnabled": true
    According to ChatGPT the frequency of -1 means as fast as possible. These changes fix the problem and I get motion now.
  17. Thomas Vidal
    Thomas Vidal New Member
    16Coins
    Title: Stream Deck control of Profile Intensity slider in SimTools v3 - is it possible?
    Message:
    Hi everyone, and hi yobuddy,
    I'm a sim racer using SimTools v3 Pro with F1 2023 and a seat mover, controlled via a Stream Deck. My goal is simple: adjust the Profile Intensity slider in real time while racing, without interrupting the game (which runs in borderless fullscreen).
    I've spent a lot of time trying every approach I could think of:
    • ❌ PostMessage / SendMessage to the window — the slider is custom drawn, doesn't respond
    • ❌ Mouse drag via AHK — the game captures all mouse input in borderless fullscreen
    • ❌ Editing Default_Motion.cfg directly — SimTools only writes this file on exit, not in real time
    • ❌ Memory scanning with Cheat Engine — couldn't find a stable address
    • ❌ Network/TCP — netstat shows SimTools has no open ports
    • ❌ No Remote Profiler addon exists for v3 (only v2)
    I know SimTools v3 has an Addon API described as supporting "remote profiler for adjusting settings on the fly" — is there any official or community addon that does this? Or is there a TCP/named pipe interface I missed?
    Ideally I'd love a way to send a simple command like "intensity=80" to SimTools from AHK or a small script, without touching the mouse or keyboard focus.
    Any help would be greatly appreciated — I'm sure other Stream Deck users would benefit from this too!
    Thanks, Tom
  18. Josh_Possa
    Josh_Possa Active Member
    Catalunya
    641Coins
    Hi! I own a Pro license and recently I configured Vibe for RPM and road for MSFS 2024. Landing gear is present but is not working in any plane. Also I see flaps isn't present.
    I own a simshaker for aviators that implements quite well the vibrations for (in my case a DIY) butkicker but since I switch from Flypt to simtools is not possible to run it together.
    Is it possible to acces and edit the msfs plugin code to add flaps and fix landing gear? If not I'll try creating a new plugin with the fixes with AI help.
    Thanks!
  19. Ralf Nass
    Ralf Nass New Member
    31Coins
    Motion platform
    Hi, with the new Assetto Corsa EVO 0.6 release, Kunos has changed shared memory, Simtools plugin is not longer functioning. Would it be possible to update the plugin? Thanks a lot
  20. vistol5100
    vistol5100 New Member
    169Coins
    We'll have to wait for the plugin update. Today, with the update, I also noticed it stopped working. I imagine someone is already working on it.
