Motor drivers
Motor driver
All about motor drivers
Sticky
Monster Moto testing before use
There are normally timelines to be met to be eligible for refunds on faulty boards, so it pays to test them on arrival.
You can follow @SeatTime's advise and use an oscilloscope: http://www.xsimulator.net/community...otors-mms-and-arduinos.6948/page-8#post-81280
Or do a bench test with a multimeter before installing, as @SilentChill demonstrates here: https://www.xsimulator.net/communit...of-motion-sim-project.8448/page-6#post-111669
Sticky
BEGINNERS - PLEASE READ FIRST!!
- Are you are a complete noob and you defy any wiring experience? (BTW no electronics knowledge is needed)
- Do you hate reading (easy) manuals?
- Are you using 300W or lower powered motors with no plans to expand your system at some point in the future with stronger motors, like DC winch motors?
- Do you have a tendency to rush into jobs?
If you do plan on using MotoMonster and an Arduino (which is a great choice) then please ensure you read, fully understand and follow all of the guides in the FAQs before posting a question:
http://www.xsimulator.net/community/faq/motomonster.11/category
http://www.xsimulator.net/community/faq/arduino.6/category
If you follow all these suggestions then success is guaranteed.
Do not expect community MotoMonster troubleshooting support if you:
- Do not bother to upload videos or pictures clearly showing all wiring.
- Expand your system by using 4 MMs - and you use any wire colors without any logic resulting in spaghetti syndrome (eg. black for "+")
- Ignore troubleshooting advice regarding testing your components and wiring.
Reasonably Priced 100A Motor Controllers
knaufinator 6DOF open source AASD15A servo PCB & platform code
Motion4Sim 6dof+ AASD15 Servo Motion Controller
IBT2
https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
Edit for Mode 2 in the SMC3 code like this: https://www.xsimulator.net/community/threads/problems-with-my-simulator.15382/#post-207320
Cooling mod for IBT-2 with BTN8982 Hbridges included by @Peter_the _machinist: https://www.xsimulator.net/communit...r-ibt-2-with-btn8982-hbridges-included.17957/
JRKs
Cytron MD13S for SMC3
AMC-AASD15A servo controller
Bajer E-stop box with led light buttons for AMC-AASD15A servo controller: https://www.xsimulator.net/community/threads/amc-aasd15a-servo-controller.13945/page-7#post-199933
AMC1280USB Motion Simulator Controller
Moto Monster only one direction
SaberTooth Motor Driver (max 36V)
https://www.xsimulator.net/communit...d-powerful-motor-driver-update-02-22-17.8606/
Sabertooth 2x32 manual: https://www.dimensionengineering.com/datasheets/Sabertooth2x32.pdf
Sabertooth 2x32 resistor calculator: https://www.dimensionengineering.co...or?batteryvoltage=12¤t=8&calc=Calculate
H-bridges - DC motor controllers
Pololu Jrk 12v12 USB Motor Controller with Feedback
99$ https://www.pololu.com/product/1393
one per motor
talk directly with Simtools via USB
Pololu software for PID tuning (no coding)
► motomonster
one board for two 12V DC motors (or one bigger by @Pit )
driven by 2 x 3 pins (1 PWM for Speed and 2 for Direction)
require to be driven by an Arduino
home made:
► by @Spyderwash http://www.xsimulator.net/community...lator-with-rear-wipers.4896/page-2#post-76942
Xilence Cooler for Moto Monster (Sparkfun)
24v motor driver - where to buy
http://www.xsimulator.net/community/threads/24v-motor-driver-where-to-buy.6987/
@Grigory found there were some code changes needed when using SMC3 code with MODE 4 and Sabertooth to reduce noise, see here for details and modified code: https://www.xsimulator.net/communit...nd-windows-utilities.4957/page-54#post-115532
Monster Moto Shield as a single motor driver
MonsterMoto: HowTo: more power (30A current, 60A peak) for 200-300W motors
http://www.xsimulator.net/community...cts-as-a-single-motor-driver-more-power.5482/
Moto Monster HowTo: more power (60A current, 120A peak) for 600-800W motors
http://www.xsimulator.net/community...bridge-60a-continuous-and-120a-peak-12v.6537/
