Registering and use tips for SimTools 2.0
How to Register SimTools 2.0: https://www.xsimulator.net/community/threads/how-to-register-simtools-2-0.9720/
Upgrading from the DIY to Pro SimTools license can be done by Log into SimTools.us. Use the email you purchased the Licenses with, and if you don't have a password, click reset password. There you will find an upgrade path for a DIY license to Pro.
Installing SimTools 2.0 on a domain: https://www.xsimulator.net/community/threads/installing-2-0-on-a-domain-read-this.9526/#post-122320
SimTools 2.0 Input Settings - The difference from SimTools 1.3 to SimTools 2 in setup is that in the Interface Settings instead of axis defined like this <Axis1> it now has designate grouping for a or b in SimTools 2 for each axis assignment, like this <Axis1a><Axis2a>
Backup 1.3 - Before you remove 1.3, you can backup this folder by making a zipped copy - C:\Users\(Your User Folder)\AppData\Local\SimTools
Then if you ever want to go back, simply install 1.3 and replace this folder with the zipped copy.
You can look up your SimTools license number, just log into SimTools.us: https://simtools.us/member-login/
Be aware that SimTools may trigger a Widows Trojan warning, it is a false positive, see the explanation here by the SimTools developer @yobuddy: https://www.xsimulator.net/communit...r-as-trojan-win32-rundas-b.10708/#post-138738
If you are using Google Chrome and there is a message that the download could contain malicious code, again it is a false positive, please ignore that message. Its a false positive error which only appears in Chrome.
SimTools (motion software) and Xsimulator.net (community and community developed plugins) are two separate entities, see here for details on the relationship and revenue arrangements between the two: https://www.xsimulator.net/community/faq/simtools-and-xsimulator-partnership-explained.275/
A SimTools license only covers the SimTools software, it does not cover access to plugins.
Access to plugins can be purchased with forum activity coins or real money: https://www.xsimulator.net/community/faq/coins-and-how-to-download-plugins.2/
Licence & Installation
Jan 10, 2017
17892
