To enable motion the following methods can be used:
- UDP port forwarding setup on the router
- or; Using the loopback utility
- or; Using an app such as Simhub or Simcommander etc, to forward the UDP
There is a Loopback Exemption Manager you can use.
https://github.com/tiagonmas/Windows-Loopback-Exemption-Manager
https://cdn.discordapp.com/attachme.../557161448363655198/enableloopbackutility.exe
In Forza, Data out on. IP: 127.0.0.1 Port: 4123
Open WindowsLoopbackManager.exe as administrator.
Then enable all the loopback for all the Forza entries and save.
In the game enable data out on and ip 127.0.0.1 port 4123.
