Sinusoid Generator
• Drag'n'drop the zip file into the SimTools_PluginUpdater.exe as usual
• Run GameManager in admin mode
• Patch the "game" (select SimTools installation directory; that's also the reason, why you need to run GameManager in admin mode when patching)
• Start GameEngine
• Run SimTools_CurveGenerator.exe from the SimTools installation directory
• Select the type of curve you want, select the simulated force, the IP address of GameEngine (127.0.0.1 if you run in single PC configuration) and press start.
- Aug 7, 2020
- 1117
